  2. Functional Verification
  3. ncsim for System Verilog
  • Subscribers 66
  • Views 18121
archive over 20 years ago
Hi All,
I want to run the DPI in system verilog along with cadence ncsim.
After writing the code what are the steps to compile and simulate the code?
I am using ncsim 5.40-s012.
I am using the following command for compilation :
ncsim -sv my_file.v
The place at which i am importing the 'c' function, is giving the error: parenthesis missing ('(').
Originally posted in cdnusers.org by prasad_vc
    Can you paste the code where you are importing the DPI? Without that, it's hard to know what the problem is.
    Tim
    Originally posted in cdnusers.org by tpylant
    Thanx tim,
    The problem was with tool, it needs atleast 5.60v of ncsim to do DPI.
    The steps i found out are:
    gcc -shared -fPIC -o libdpi.so c-file-name.c
    ncverilog +sv31a sv-file-name.sv
    Vivek.
