  2. Functional Verification
  3. Need help regarding interface usage in Systemverilog...
  • Subscribers 66
  • Views 17384
archive over 20 years ago
Hi All,
I'm having problem when i used the interface declaration in module. Pls see the error i got.
My UART DUT is a verilog module.
ncelab: *E,CUINMD (./sips_uart_bfm.sv,13|43): An interface connection must be connected to a Verilog parent (sips_uart_bfm).
module sips_uart_bfm(sips_uart_bfm_if  bfm_if, sips_uart_uart_if  uart_if, input reset,input clock);
This is an incompatible connection.  A Verilog interface must be connected
       to a port of a Verilog instance.  All other languages and connection
       types are disallowed.
Pls suggest me how to go about this.
Thanks & Regards,
Prabhu Kumar
Originally posted in cdnusers.org by prabhuk
    I've seen this error when I tried to compile an intermediate file (i.e. not top level). I'm guessing you need to have a level above sips_uart_bfm that instantiates the sips_uart_bfm_if as well as sips_uart_bfm. Then you need to compile all three of those files (top, bfm, if) and that should resolve this problem.
    Tim
    Originally posted in cdnusers.org by tpylant
