  2. Functional Verification
  3. SystemVerilog Data-types (code)
  • Subscribers 66
  • Views 30680
archive over 20 years ago
I am sharing the little work i did on SystemVerilog. This can be the starting point for anyone new to the language. If you all can enhance this by adding your part, will really make an practical guide for the language.
// Program for Data-Types of SystemVerilog
// Author : Vivek Prasad
// Date   : 15 Sep 2006
// Covers : shortint, int, real, time, reg, bit, logic, string, enum, struct
//          class, functions, tasks.
module data_types;
//**************************Data-Types**************************************//
  time dt_time         = 1ms;    // dt_time is defined as time variable.
  shortint dt_decimal  = 10;     // 16-bit representation of decimal 10.
  shortint dt_octal    = 8'o17;  // Octal "317" assigned to dt_octal.
  bit [7:0]dt_binary   = 8'd42;  // dt_binary will be "00101010".
  logic [7:0]dt_hex    = 8'hAX;  // 16-base-AB
  byte     dt_byte     = "V";    // ASCII "V" character.
  int      dt_signed   = -5;     // 32-bit represen'n of -5 in one's compl.
  real     dt_real     = 3.141;  // Real number representation.
  real     dt_exp      = 1.0e6;  // Floating point representation.
  reg [3:0]dt_reg      = 4'b01XZ;// 4-value "reg" data-type.
//  string   dt_name     = "{Vivek Prasad\n}";  // Not supported by ncsim5.6
//  int dt_cast;   // could not obtain the reult.
//************************Data-Types****************************************//
//****************************Enum********************************************//
  typedef enum bit {NO,YES} boolean;
  boolean  dt_enum;      // To use boolean as variable-type, use typedef.
  assign dt_enum = YES;
//****************************Struct******************************************//
  typedef struct packed {
                 bit [7:0] opcode;
                 bit [23:0]addr;
                 } IR;   // To use IR as variable-type, use typedef.
  IR dt_instr;
//****************************Class*******************************************//
  class adder;
    int a;
    int b;
    int sum;
    task add();
      sum = a + b;
    endtask
    function void init();
      a = 2;
      b = 5;
      $display("a=%d & b=%d",a,b);
    endfunction
  endclass
  adder dt_add = new();
//****************************Casting*****************************************//
//  dt_cast = int'(3.141);
//****************************Initialization**********************************//
  initial
  begin
    $display("Time Literal : %t\n",dt_time);
    $display("Decimal Literal : %d\n",dt_decimal);
    $display("Octal Literal : %o\n",dt_octal);
    $display("Binary Literal : %b\n",dt_binary);
    $display("Hex Literal : %h\n",dt_hex);
    $display("Byte Literal : %h\n",dt_byte);
    $display("Signed Literal : %d\n",dt_signed);
    $display("Real Literal : %f\n",dt_real);
    $display("Float Literal : %f\n",dt_exp);
    $display("Reg Literal : %b\n",dt_reg);
//    $display("String Literal : %s\n",dt_string);
    $display("Enum Data-type : %b\n",dt_enum);
    $display("Structure Example");
    dt_instr.opcode = 8'h12;
    dt_instr.addr   = 24'habcdef;
    $display("Struct Member1 : %h",dt_instr.opcode);
    $display("Struct Member2 : %h\n",dt_instr.addr);
    $display("Class Example");
    dt_add.init();
    dt_add.add();
    $display("Sum = %d\n",dt_add.sum);
//    $display("Casting = %d\n",dt_cast);
    $finish;
  end
endmodule
// Output, as on ncsim5.6
// Time Literal    :  1000000
// Decimal Literal :  10
// Octal Literal   :  000017
// Binary Literal  :  00101010
// Hex Literal     :  ax
// Byte Literal    :  56      // ASCII Value of "V"
// Signed Literal  :  -5
// Real Literal    :  3.141000
// Float Literal   :  1000000.000000
// Reg Literal     :  01XZ
// Enum Data_type  :  0
// Structure Example
// Struct Member1  :  12
// Struct Member2  :  abcdef
// Class Example
// a = 2 & b = 5
// Sum = 7
Vivek Prasad
Originally posted in cdnusers.org by prasad_vc
    This is a great showing of all the different data types in SV. In actual usage, I would recommend putting the typedefs into packages. This cleans up your code and makes it easy to reuse the data types since they are in a stand alone package/file.
    Example:
    [u]types_pkg.sv[/u]
    package types_pkg;
    typedef enum bit {NO,YES} boolean_t; // adding _t extension makes it easier to identifiy as a typedef
    bit ?:0] opcode;
    bit ?:0]addr;
    } IR_s; // To use IR as variable-type, use typedef.
    endpackage : types_pkg
    Then you "import" the package(s) into whatever modules you need those typedefs.
    Example:
    module data_types;
    import types_pkg::*;
    boolean_t flag; // boolean is a typedef from types_pkg
    endmodule
    You could also put the display statements into a general purpose task and put that task into the package as well.
    Thanks for the examples,
    Tim
    Originally posted in cdnusers.org by tpylant
    archive over 19 years ago
    Just to complete this examples for strings (partially works in IUS5.83 and complete in IUS6.0)
    ----file: top.v-----------
    module top ();
    /import "DPI-C" context pass_string_c= task pass_string_sv(input string a);
    import "DPI-C" context string_c2v_c= function string string_c2v_sv();
    string some_string;
    // This doesnt work in IUS583, will work in IUS6.0
    export "DPI-C" print_string_c = function print_string_sv;
    function void print_string_sv(input string aaa);
    $display("Print_string from Verilog % s", aaa);
    endfunction
    initial
    begin
    some_string = "pass it ON";
    // comment in line below when running IUS6.0
    pass_string_sv(some_string); // pass string to C
    $display("Verilog: % s \ n", string_c2v_sv() ); // get string from C
    $finish;
    end
    endmodule
    ----file: main_task.c----------
    #include
    #include
    // to use io_printf
    #include
    void pass_string_c(const char* a) {
    printf("C: %s \n", a);
    print_string_c("string passed from C"); // This doesnt work in IUS583
    const char* string_c2v_c(void) {
    io_printf("C: give up a string \n"); // io_printf from vpi will print to ncsim.log file, can use printf()
    return "Gimme String";
    -------File: RUN_NC (script)-------------
    rm -r INCA_libs
    rm *.so
    rm *.log
    rm *.h
    # Create .h file for Exported tasks/functions only
    # (imported function do NOT need .h file):
    ncverilog +sv top.v +ncdpiheader+dpi.h +elaborate +ncelabargs+-messages
    # ncvlog -sv top.v -mess
    # ncelab top -sv -dpiheader dpi.h -mess
    gcc -fPIC -shared -o main_task.so main_task.c -I/`ncroot`/tools/inca/include
    ncverilog +sv top.v +sv_lib=main_task.so +access+r +ncsimargs+"-sv_root ./"
    -----simulation results-----
    ncsim> run
    C: pass it ON
    Print_string from Verilog string passed from C
    Verilog: C: give up a string
    Gimme String
    Simulation complete via $finish(1) at time 0 FS + 0
    Originally posted in cdnusers.org by tmackett
