  2. Functional Verification
  3. Creating fifo channel between class objects
  • Subscribers 66
  • Views 17205
archive over 19 years ago
I'm trying to create a fifo channel between two classes.. I tried using Queue in an interface and pass the interface to the virtual interface of the class .. Not currently supported..
Tried using a global queue and passing its reference to the classes I get the "As a temporary implementation restriction, an array class member reference is not permitted in this context" error..
Any suggestions for a work around..
Thanks..
Following is the code and the log file..
package fifo1;
class genfra;
rand bit [31:0] dword1;
rand bit [31:0] dword2;
endclass :genfra
class crefra;
local genfra fifoc[$] ;
genfra temp1 ;
integer success,i,dly;
function new(ref genfra fifo[$]);
fifoc = fifo;
endfunction
task gennpush();
for(i = 0 ; i < 20 ;i++)
begin
temp1=new();
success = temp1.randomize();
success = randomize(dly) with {dly > 2;dly < 5;};
$display("time=%d.. temp1.dword1 = %08x ",$time,temp1.dword1);
$display("time=%d.. temp1.dword2 = %08x ",$time,temp1.dword2);
fifoc.push_back(temp1);
#dly;
end
endtask
endclass
class prifra;
local genfra fifop[$] ;
fifop = fifo;
endfunction
task popnprint();
genfra temp2 ;
forever
begin
$display("time=%d..before pop ",$time);
if(fifop.size())
begin
#5;
$display("fifo size before pop ",fifop.size());
temp2=fifop.pop_front();
$display("time=%d.. temp2.dword1 = %08x ",$time,temp2.dword1);
$display("time=%d.. temp2.dword2 = %08x ",$time,temp2.dword2);
$display("fifo size after pop ",fifop.size());
end
else
#1;
end
endtask
endclass
endpackage
module top;
timeunit 1ns;
int success,i;
import fifo1::*;
genfra fifo[$] ;
crefra cf = new(fifo);
prifra pf = new(fifo);
initial
begin
fork
cf.gennpush();
pf.popnprint();
join any
$finish;
end
final $display("time=%d Ending Simulation ",$time,);
endmodule
log file :
ncverilog: 05.83-p002: (c) Copyright 1995-2006 Cadence Design Systems, Inc.
TOOL: ncverilog 05.83-p002: Started on Dec 14, 2006 at 19:44:23 IST
ncverilog
-l
./transcript.clachan.log
+ncaccess+rw
+notimingchecks
+libext+.v
+sv
+svseed=35
clachan.sv
file: clachan.sv
fifoc = fifo;
ncvlog: *E,WOUPYR (clachan.sv,21|4): As a temporary implementation restriction, an array class member reference is not permitted in this context.
fifoc = fifo;
ncvlog: *E,WOUPSR (clachan.sv,21|11): A reference to an entire array is not permitted in this context [SystemVerilog].
fifop = fifo;
ncvlog: *E,WOUPYR (clachan.sv,43|4): As a temporary implementation restriction, an array class member reference is not permitted in this context.
fifop = fifo;
ncvlog: *E,WOUPSR (clachan.sv,43|11): A reference to an entire array is not permitted in this context [SystemVerilog].
package worklib.fifo1:sv
errors: 4, warnings: 0
import fifo1::*;
ncvlog: *E,NOPBIND (clachan.sv,73|11): Package fifo1 could not be bound.
genfra fifo[$] ;
ncvlog: *E,SVNOTY (clachan.sv,74|5): Syntactically this identifier appears to begin a datatype but it does not refer to a visible datatype in the current scope.
genfra fifo[$] ;
ncvlog: *E,ILLPRI (clachan.sv,74|12): illegal expression primary [4.2(IEEE)].
genfra fifo[$] ;
ncvlog: *E,EXPIDN (clachan.sv,74|15): expecting an identifier [3.2][3.8][3.9(IEEE)].
ncvlog: *E,EXPSMC (clachan.sv,75|10): expecting a semicolon (';') [12.3.2(IEEE)].
ncvlog: *E,EXPSMC (clachan.sv,75|20): expecting a semicolon (';') [12.3.2(IEEE)].
ncvlog: *E,EXPSMC (clachan.sv,76|10): expecting a semicolon (';') [12.3.2(IEEE)].
ncvlog: *E,EXPSMC (clachan.sv,76|20): expecting a semicolon (';') [12.3.2(IEEE)].
$finish;
ncvlog: *E,MISEXX (clachan.sv,85|13): expecting an '=' or '<=' sign in an assignment [9.2(IEEE)].
module worklib.top:sv
errors: 9, warnings: 0
ncvlog: *F,NOTOPL: no top-level unit found, must have recursive instances.
ncverilog: *E,VLGERR: An error occurred during parsing. Review the log file for errors with the code *E and fix those identified problems to proceed. Exiting with code (status 2).
TOOL: ncverilog 05.83-p002: Exiting on Dec 14, 2006 at 19:44:23 IST (total: 00:00:00)
Originally posted in cdnusers.org by mirzani
    I used a mailbox to do what you want. Although mailboxes aren't formally supported in IUS, I included a mailbox class that works the same way (all files attached).
    Here's the main change to your code:
    package fifo1;
    import mailbox::*;
    class genfra extends mb_item;
    endclass :genfra
    class crefra;
      mailbox   fifoc ;
      genfra    temp1 ;
      int       dly;
      function new(mailbox fifo);
        fifoc = fifo;
      endfunction
      task gennpush();
        repeat (20) begin
          temp1=new();
          assert(temp1.randomize());
          assert(randomize(dly) with {dly > 2;dly < 5;});
          fifoc.put(temp1);
          #dly;
        end
      endtask
    endpackage
    module top;
      timeunit 1ns;
      import fifo1::*;
      import mailbox::*;
      mailbox fifo = new(10);
    endmodule
    Originally posted in cdnusers.org by tpylant
    mbox_ex.tar.gz
