  2. Functional Verification
  3. Pass string to $system in SystemVerilog?
  • Subscribers 66
  • Views 21097
archive over 19 years ago
Hi, I want to run perl command with dynamic argument in SystemVerilog. And I use Cadence IUS583. When I try to pass a string to $system(), the ncvlog said "Using String without index is not supported in the given context." The code I write like below, //--------------------- string perl_cmd_str = ""; $sformat(perl_cmd_str,"perl ./perl/test_opt_file.pl -a %0d -b 4", data_a); $display("string is %s\n", perl_cmd_str); $system (perl_cmd_str); //--------------------- Any suggestion on how to input string to $system()? Thanks! Davy
Originally posted in cdnusers.org by davyzhu
    It doesn't address the question of passing a string to $system, but it does solve your problem:
    module test;
    int f;
    int data_a;
    string perl_cmd_str = "echo ";
    initial begin
      f=$fopen("run_sys.pl", "w");
      assert(randomize(data_a) with {data_a >= 0;});
      $fdisplay (f, "%s", perl_cmd_str);
      $system ("run_sys.pl");
    end
    endmodule
    Originally posted in cdnusers.org by tpylant
    Hi tpylant,
    I tried to change
    string perl_cmd_str = " ";
    to
    reg [100*8:1] perl_cmd_str = " ";
    And it turned out to be OK!
    I found Cadence SV implementation is ambigous on String and one-dimentional reg array.
    Best regards,
    Davy
    The above reg ??*8:1]
    is
    reg [ 100*8 : 1 ]
    Best regards,
    Davy
