  2. Functional Verification
  3. Share Queue between class?
  • Subscribers 66
  • Views 16856
archive over 19 years ago
Hi all,
I am using IUS583. And I want to do transaction layer class object transfer using Queue.
I think there maybe two methods listed below.
1. share queue with two different class
2. share queue (maybe local queue) with two different tasks within one class
My queue contain class object, is it feasible in IUS583? And is there any simple example to do that work?
I have write method 1 and method 2 ,but it seems IUS583 always give out ncelab error:
ncelab: *E,CUVHNF Hierarchical name component lookup failed at 'cmd_queue'.
//method 1 snippet
module top_tb;
class cmd_c;
endclass
cmd_c cmd_queue[$];
class transaction_gen;
task run;
    cmd_queue.push_back (cmd)
endtask
endclass
//method 2 snippet
module top_tb;
class cmd_c;
endclass
local cmd_c cmd_queue[$];
task run;
endtask
endclass
Best regards,
Davy
Originally posted in cdnusers.org by davyzhu
    The following code worked with : ncverilog: 05.83-p002:
    module top;
    class cmd_c;
    integer i;
    endclass
    cmd_c cmd_queue[$];
    cmd_c cmd = new;
    task run;
    cmd_queue.push_back (cmd);
    $display("cmd Pushed..");
    endtask
    endclass
    transaction_gen tg = new;
    initial
    begin
    tg.run;
    $finish;
    end
    endmodule
    Originally posted in cdnusers.org by mirzani
    Hi mirzani,
    Thanks a lot! Your code work fine!
    Best regards,
    Davy
