  2. Functional Verification
  3. Manipulating Unpacked Arrays using DPI
  • Subscribers 66
  • Views 15930
archive over 19 years ago
I'm sharing this code which is a demo of how to manipulate a SystemVerilog Unpacked Array using DPI. This code will work with IUS5.83. -----file top.v-------- module top (); `define ARRAY_LO 4 `define ARRAY_HI 13 int xyz[`ARRAY_HI: `ARRAY_LO]; // define import function to pass reference to // open array of int's. This makes the call generic for // any array size. import "DPI-C" context function void doArray(inout int abc[] ); initial begin // stuff the packed structure with data for (int i = `ARRAY_LO; i #include // Created by Todd Mackett (tmackett@cadence.com) with some help from // Abhishek Raheja void doArray(const svOpenArrayHandle x ) { // pass in open handle io_printf("Array Handle is %x \n", x); io_printf("Array Pointer is %x \n", svGetArrayPtr(x) ); io_printf("Array Left %d, Array Right %d \n", svLeft(x,1), svRight(x, 1) ); io_printf("Array Low %d, Array High %d \n", svLow(x,1), svHigh(x, 1) ); //io_printf("Length %d \n", svLength(x,1) ); // not implemented 6.02v138 // io_printf("%d \n", svDimensions(x )); // not implemented 6.02v138 io_printf("Size of Array in bytes %d \n", svSizeOfArray(x) ); // returns bytes // Print out 1Darray contents using Array Low to High indexes int i; for (i= svLow(x,1); i run Array Handle is 938d8c8 Array Pointer is 93f6a00 Array Left 13, Array Right 4 Array Low 4, Array High 13 Size of Array in bytes 40 DPI: 4 is: 77775559 DPI: 5 is: 7777555a DPI: 6 is: 7777555b DPI: 7 is: 7777555c DPI: 8 is: 7777555d DPI: 9 is: 7777555e DPI: 10 is: 7777555f DPI: 11 is: 77775560 DPI: 12 is: 77775561 DPI: 13 is: 77775562 DPI2: 0 22221111 DPI2: 1 22221112 DPI2: 2 22221113 DPI2: 3 22221114 DPI2: 4 22221115 DPI2: 5 22221116 DPI2: 6 22221117 DPI2: 7 22221118 DPI2: 8 22221119 DPI2: 9 2222111a Vlog: 4 22221111 Vlog: 5 22221112 Vlog: 6 22221113 Vlog: 7 22221114 Vlog: 8 22221115 Vlog: 9 22221116 Vlog: 10 22221117 Vlog: 11 22221118 Vlog: 12 22221119 Vlog: 13 2222111a ncsim: *W,RNQUIE: Simulation is complete. ncsim> exit TOOL: ncverilog 05.83-p003: Exiting on Feb 05, 2007 at 11:29:36 EST (total: 00:00:03)
Originally posted in cdnusers.org by tmackett
