  2. Functional Verification
  3. Manipulating Strings Using DPI
  • Subscribers 66
  • Views 16322
archive over 19 years ago
I'm sharing this code. This is an example of passing strings back and forth from SystemVerilog and DPI. Some of these features aren't available until IUS6.0. ----file top.v-------- module top (); import "DPI-C" context pass_string_c= task pass_string_sv(input string a); import "DPI-C" context string_c2v_c= function string string_c2v_sv(); string some_string; // This doesnt work in IUS583, will work in IUS6.0 export "DPI-C" print_string_c = function print_string_sv; function void print_string_sv(input string aaa); $display("Exported Verilog String= %s", aaa); endfunction initial begin some_string = "pass it ON"; // enable when running IUS6.0 pass_string_sv(some_string); // pass string to C $display("Verilog: %s \n", string_c2v_sv() ); // get string from C $finish; end endmodule -----file main_task.c----- #include #include // to use io_printf (prints to ncsim.log) #include void pass_string_c(const char* a) { io_printf("DPI: %s\n", a); // now call exported function print_string_c("string passed from C"); // This wont work in IUS583 } const char* string_c2v_c(void) { io_printf("C: give up a string\n"); return "Gimme String"; } -----file: RUN_NC (script)------ rm -r INCA_libs rm *.so rm *.log rm *.h # Create .h file for Exported tasks/functions only # (imported function do NOT need .h file): ncverilog +sv top.v +ncdpiheader+dpi.h +elaborate +ncelabargs+-messages # ncvlog -sv top.v -mess # ncelab top -sv -dpiheader dpi.h -mess gcc -fPIC -shared -o main_task.so main_task.c -I/`ncroot`/tools/inca/include ncverilog +sv top.v +sv_lib=main_task.so +access+r +ncsimargs+"-sv_root ./" ----file: ncverilog.log (IUS6.02)----------- ncsim> run DPI: pass it ON Exported Verilog String= string passed from C Verilog: C: give up a string Gimme String Simulation complete via $finish(1) at time 0 FS + 0 ./top.v:22 $finish; ncsim> exit
Originally posted in cdnusers.org by tmackett
