  2. Functional Verification
  3. Example Test Bench Using Interface and Classes
  • Subscribers 66
  • Views 15366
archive over 19 years ago
I'm sharing this code, which is an example of using an SV Interface to transmit a class of data & functions to a DUT. // Todd Mackett Cadence Design Systems // ncverilog class_across_interface.sv +sv +linedebug +gui // tested wtih IUS5.83s1 /* top-------------------------- | test --->interface---->dut | |----------------------------- */ package mypack; class some_class; //class is the rudimentry data container int some_int; real some_real; protected string some_string; // needs to be protected for IUS5.83 function void set_data (int i, real r, string s); some_int =i; some_real = r; some_string = s; endfunction task get_data(output int i, output real r, output string s); i = some_int; r = some_real; s = some_string; endtask function void print_data(); $display("Int: %d, Real: %f, String: %s", some_int, some_real, some_string); endfunction endclass endpackage // ------ // This channel is an interface that is a queue of classes interface myIF; import mypack::*; event some_event; some_class some_classQ[$]; function int some_classQ_size(); return some_classQ.size(); endfunction task push_class_in_Q(input some_class Qin); some_classQ.push_front(Qin); endtask task pop_class_out_Q(output some_class Qout); Qout = some_classQ.pop_back(); endtask endinterface // ----------------- module top(); int top_int; reg clk = 'b1; initial forever clk = #10 ~clk; // system clk myIF myIFi(); // instantiate interface test testi(clk, myIFi); dut duti(clk, myIFi); endmodule // -------------- // The test module create a class of information and puts it in the // channel (a queue in the interface) module test (input clk, myIF myIFi); import mypack::*; int i; real r; string s; initial #200 $finish; some_class top_class; always @(posedge clk) begin top_class = new; // randomize the data per class object i = $urandom_range(5,1); randcase 1: r = 3.14; 1: r = 123.456; 1: r = -943.825; endcase randcase 1: s = "IUS SystemVerilog"; 1: s = "Cadence"; 1: s = "Who needs VHDL?"; endcase top_class.set_data(i, r, s); // set the values into class myIFi.push_class_in_Q(top_class); // transmit the class -> myIFi.some_event; // cause the event end endmodule // ------------- // The dut module consumes the class when the event is valid // and displays its contents as it comes across the interface module dut (input clk, myIF myIFi); import mypack::*; some_class dut_class =new; always @(myIFi.some_event) // process event begin $display("\nQueue Size %d",myIFi.some_classQ_size() ); myIFi.pop_class_out_Q(dut_class); dut_class.print_data(); end endmodule
Originally posted in cdnusers.org by tmackett
    Hi Todd,
      Thanks for the code share, it helps!
    Your compile command is:
    Recently CDN ran a Specman Debug survey which I also gave my inputs. Will NC
    reuse some of the excellent debug capabilities of Specman or will it all be
    newly built under Simvision? I would prefer the former as Veristy had done
    an excellent job there and CDN has the enviable lead among vendors in that
    domain. Esecially on this example you showed class under module and +gui option
    Are classes/instances/objects visible as waveform in Simvision? As you would know
    Specman had a nice way of doing it for years, it will be really sad if that can't
    be reused for SV under NC.
    BTW - will there by any consolidated report on the debug survey conducted recently
    by CDN?
    Ajeetha, CVC
    www.noveldv.com
    Originally posted in cdnusers.org by ajeetha
