  2. Functional Verification
  3. waveform dump
  • Subscribers 66
  • Views 31601
waveform dump
archive over 19 years ago
I'm trying to dump all DUT signals in a .trn file. A .trn file is getting created when i use
$recordfile("filename.trn");
$recordvars();
but this file doesnot contain any signals or dump. Please guide me on how to dump all dut signals internal to the DUT as well in IUS5.83.
Originally posted in cdnusers.org by chaitu2k
    Problem fixed with -access +rcw
    A slight correction there.It is +access+rcw
    Originally posted in cdnusers.org by sundar_80
    +access+rcw for ncverilog command and -access+rcw for nc elaboration
    Just for the record: the rcw flags can be used to specify exactly how you will interact with the simulator.
    If you will only want to probe waveforms, then "-access +r" is enough, because the "r" flag turns on read access to the design.
    If you want to use TCL commands like "force", or you have PLI / VPI code that drives signals, then you need to add the "w" flag.
    Finally the "c" flag turns on connectivity tracing, to allow the SimVision debug stuff like "trace drivers" to work.
    Hope this helps.
    Originally posted in cdnusers.org by stephenh
