  2. Functional Verification
  3. interface for bidirectional pins
  • Subscribers 66
  • Views 16051
archive over 19 years ago
Hi
I trying to interface a bidirectional pin in sysytemverilog. in my interface declaration i have declared it as wire and in clocking block as inout...in my top module i'm using a reg to get values and then using the following syntax
assign my_if.biDir_pinname = reg_name;
in simulation i'm observing X. i also have to do a weak pullup. please guide on how to model and successfully interface bidirectional pins. i'm using cadence IUS5.83
Originally posted in cdnusers.org by chaitu2k
    You will have to treat the wire in the interface like you would treat any wire in Verilog. It can only have one driver at a time. I believe you will have to conditionally assign reg_name:
    assign my_if.biDir_pinname = (enable_me) ? reg_name : 'bz;
    Here is a mini example:
    interface mod_if;
    wire [7:0] bidir_bus;
    logic enable1;
    endinterface : mod_if
    module one (interface my_if);
    assign my_if.bidir_bus = (enable1) ? 8'h11 : 8'hz;
    endmodule : one
    module two (interface my_if);
    assign my_if.bidir_bus = (enable1) ? 8'hz : 8'h22;
    endmodule : two
    module top();
    mod_if my_if();
    one m1 (my_if);
    two m2 (my_if);
    initial begin
    my_if.enable1 = 1;
    repeat (4)
    #1 my_if.enable1 = ~my_if.enable1;
    end
    initial $monitor(my_if.enable1,, my_if.bidir_bus);
    endmodule : top
    Kathleen Meade
    Originally posted in cdnusers.org by kameade
