  2. Functional Verification
  3. About URM library
  • Subscribers 66
  • Views 15345
About URM library
archive over 19 years ago
Hello Cadence,
 It’s happy to hear Cadence release its own class based SV library!
 I found in urm_svcb_ref.pdf page 9, “The URM base class library is an open-source, SystemVerilog-based class library of verificationcomponent building blocks and interfaces.” Thus, I can integrate uRM into my project by myself.
 So could you please tell me what the open-source licence is? And how can I get the code?
Best regards,
Davy
Originally posted in cdnusers.org by davyzhu
    Hi Davy,
    I'm the product marketing directory for SystemVerilog at Cadence. Its true, the class-based view of our Plan-To-Closure methodology is available in a limited release now. We are just completing a few more customer engagements and plan to release it shortly.
    The view of our methodology for design teams is currently available, with an associated library. The main difference is in the structure of the testbench. The class-based view uses OO to construct the environment while the module-based view uses modules. We have found that designers like the module view because the static structure mimics the hardware structures they are used to seeing and is easier for them to debug. Both views can be used together on a design so the whole team can be trained on one methodology where each team member uses the appropriate view thus maximizing the resource you can put on verification.
    Please contact me at asherer@cadence.com and lets talk about how and when you can access the full methodology, examples, and library. While we are selective about our engagements right now, but we expect to lift that quite soon. I know that lots of folks read this forum, so please don't be shy about asking for access. We'll also post here when we confirm the date for general release.
    Adam Sherer
    978 262 6389
    asherer@cadence.com
    Originally posted in cdnusers.org by Adam.Sherer
    Hi Adam,
    Thank you so much for the clear explanation!
    And I have send a email to you.
    Best regards,
    Davy
