  2. Functional Verification
  3. parsing the arguments from command line
  • Subscribers 66
  • Views 23332
archive over 19 years ago
My requirement is that from the command line,  I need to pass arguments.  And in the system verilog class, I need to parse the argument and based on that I have to set some constraints.
For an example,  I have 2 different packets, pkt1 and pkt2.  Suppose if I pass the arg as pkt1_25_pkt_10, pkt1 and pkt2 should be generated in the propotion of 25:10.
vsim -c ..... +test_args=" -pkt_mode  pkt1_25_pkt2_10" ....
Could you please give some clue on this ?
Thanks.
Originally posted in cdnusers.org by knrajesh29
    Hi.
    This is quite easy to do. If you have the Verilog manual, just search for "plusargs".
    Here's a small example:
    if ( $test$plusargs("verbose") )
    $display("a relly verbose message");
    Or to get a value from the arguments:
    string testname;
    TESTNAME_GIVEN : assert ( $value$plusargs("testname+%s", testname) )
    else $fatal(1,"No +testname+xyz argument passed to simulator.");
    if ( testname == "AddrTest01" ) RunAddrTest01;
    else if ( testname == "AddrTest02" ) RunAddrTest02;
    Then when calling ncsim:
    % ncsim snapshot +testname+AddrTest01 ...
    Hope this helps.
    Steve.
    Originally posted in cdnusers.org by stephenh
    I don’t know how you will use it with vsim (modelsim) but in ncsim you can use it like shown below,
    ncsim –define pkt1=25 –define pkt2=10
    This will make the variables pkt1 and pkt2 visible in the code and and inturn you can use it like
    int packet1 = ‘pkt1;
    int packet2 = ‘pkt2;
    Now, use the packet1 with the value 25 and packet2 with value 10.
    -Vivek
    Originally posted in cdnusers.org by prasad_vc
    If $test$plusargs isn't what you need, there's another way to pass arguements  into the simulator.  Any +arguement not recognized by nceverilog or ncsim is passed into the simulator and is available for TCL.  For instance:
    ncverilog .... ... ... +test_name+mytestname
    or
    ncsim ... ... ... +test_name+mytestname
    Then this can be extracted via TCL at the NCSim command prompt:
    set covTestName "+test_name+"
    foreach i $argv {
      if {[string match [format "%s%s" $covTestName "*"] $i]} {
        set my_test_name [string range $i [string length $covTestName ] [string length $i]]
    puts "Test Name: $my_test_name"
    Originally posted in cdnusers.org by tmackett
