  2. Functional Verification
  3. C++ code through DPI simulation error?
  • Replies 18
  • Subscribers 66
  • Views 33993
archive over 19 years ago
Hi Cadence,
I have write a simple C code through DPI example, it work OK.
Then, I write a simple C++ code through DPI example. And found C++ compile and SV compile/elaboration pass. But  DPI link error? I guess its not DPI cannot found the lib as show in the ncsim log. Because the C code through DPI use the same configuration.
My friend tried the same example in Synopsys VCS and work OK.
//--- adder.cpp---
#include
#include "svdpi.h"
extern "C"{
    int sum(int a, int b);
class CADD
    private:
        int a;
        int b;
    public:
        CADD();
        ~CADD();
        int add(int a, int b);
CADD::CADD()
CADD::~CADD()
int CADD::add(int a, int b)
    int c = a +b;
    return c;
    CADD add1;
    int result = add1.add(a,b);
    printf("the result is %d\n",result);
//-- C++ compile makefile
#!/bin/sh
g++ adder.cpp -fPIC -shared -o libdpi.so -I $CDS_INST_DIR/tools/inca/include
//-- switch add to ncsim
-sv_lib ./src/test_sv/libdpi.so
Run simulation and output:
ncsim: 05.83-s003: (c) Copyright 1995-2007 Cadence Design Systems, Inc.
snapshot worklib.top:module (SSS) is up to date (no update required).
Loading snapshot worklib.top:module .................... Done
ncsim: *W,NOLDPI: Unable to load ./src/test_sv/libdpi.so.
OSDLERROR: /cad/cadence/IUS583-s003-linux/tools.lnx86/lib/libgcc_s.so.1: version cannot open shared object file: No such file or directory or file is not valid ELFCLASS32 library..
ncsim: *F,NOFDPI: Function sum not found in any of the shared object specified with -SV_LIB switch.
ncsim: Memory Usage - 17.9M program + 10.4M data = 28.3M total
ncsim: CPU Usage - 0.0s system + 0.1s user = 0.2s total (1.0s, 15.8% cpu)
Best regards,
Davy
Originally posted in cdnusers.org by davyzhu
    Davy,
    Try the following in any of your environment.
    setenv LD_LIBRARY_PATH /cad/cadence/IUS61/lnx86/tools.lnx86/systemc/gcc/3.2.3/install/lib
    Put the above statement in your .cshrc file and save and exit. Source the .cshrc file from the terminal from where you are going to invoke the simulation and finally run the simulation.
    If this doesn't work, send me the output of the following command: gcc -v
    -Vivek
    Originally posted in cdnusers.org by prasad_vc
    Hi Vivek,
    Continue the last post,
    I have check the shared lib file.
    IUS on SunOS:
    libstdc++.so.2.10.0 CANNOT found on SunOS /usr/lib
    IUS on Linux:
    Both /cad/cadence/IUS61/lnx86/tools.lnx86/lib/libgcc_s.so.1 and /usr/lib/libstdc++.so.5 CAN be found
    But what's "version `GCC_3.3' not found " mean?
    Shall the lib/libgcc_s.so.1 be compiled with GCC_3.3?
    Any Cadence engineer can show me the right direction?
    Best regards,
    Davy
    Hi Vivek,
    I add
    setenv LD_LIBRARY_PATH /cad/cadence/IUS61/lnx86/tools.lnx86/systemc/gcc/3.2.3/install/lib:{$LD_LIBRARY_PATH}
    When I compile the c++ file on Linux machine, g++ give out errors:
    g++: Internal error: Segmentation fault (program as)
    Please submit a full bug report.
    See for instructions.
    >> gcc -v
    Reading specs from /usr/lib/gcc-lib/i386-redhat-linux/3.2.3/specs
    Configured with: ../configure --prefix=/usr --mandir=/usr/share/man --infodir=/usr/share/info --enable-shared --enable-threads=posix --disable-checking --with-system-zlib --enable-__cxa_atexit --host=i386-redhat-linux
    Thread model: posix
    gcc version 3.2.3 20030502 (Red Hat Linux 3.2.3-52)
    Best regards,
    Davy
    Davy,
    Would it be possible to zip and send the programs so that i can try those out? Kindly send it to prasad_vc@yahoo.com
    GCC_3.3 means to me, the tool has used the gcc version 3.3 to build and now we are using the gcc 3.2.3 version. I guess you are right that the libgcc_s.so.1 should be compiled with GCC_3.3.
    -Vivek.
    Hi Vivek,
    I have send a email (all the related files are attached) to you, thanks!
    Best regards,
    Davy
    Hi Vivek,
    I found there is a gcc3.4.6 under IUS,
    /cad/cadence/IUS61/lnx86/tools.lnx86/systemc/gcc/3.4.6
    I have added
    setenv LD_LIBRARY_PATH /cad/cadence/IUS61/lnx86/tools.lnx86/systemc/gcc/3.4.6/install/lib:{$LD_LIBRARY_PATH}
    But when I type
    >> gcc -v
    echo always gcc 3.2.3.
    What environment parameter shall I change to force system use gcc3.4.6?
    Best regards,
    Davy
    Hi Davy.
    You probably want to set your PATH variable too:
    setenv PATH /cad/cadence/IUS61/lnx86/tools.lnx86/systemc/gcc/3.4.6/install/bin:${PATH}
    Cheers.
    Steve.
    Originally posted in cdnusers.org by stephenh
    Hi Vivek, Steve and all,
    The C++ by DPI testbench worked finally :)
    There is one hint for others who want to use it.
    Try to make sure the compiler PATH and the library LD_LIBRARY_PATH are the same version (for example, both 3.4.6).
    >> gcc -v
    find the gcc compiler version
    >> echo $LD_LIBRARY_PATH
    find the library version
    Best regards,
    Davy
