  2. Functional Verification
  3. C++ code through DPI simulation error?
  • Replies 18
  • Subscribers 66
  • Views 33992
archive over 19 years ago
Hi Cadence,
I have write a simple C code through DPI example, it work OK.
Then, I write a simple C++ code through DPI example. And found C++ compile and SV compile/elaboration pass. But  DPI link error? I guess its not DPI cannot found the lib as show in the ncsim log. Because the C code through DPI use the same configuration.
My friend tried the same example in Synopsys VCS and work OK.
//--- adder.cpp---
#include
#include "svdpi.h"
extern "C"{
    int sum(int a, int b);
class CADD
    private:
        int a;
        int b;
    public:
        CADD();
        ~CADD();
        int add(int a, int b);
CADD::CADD()
CADD::~CADD()
int CADD::add(int a, int b)
    int c = a +b;
    return c;
    CADD add1;
    int result = add1.add(a,b);
    printf("the result is %d\n",result);
//-- C++ compile makefile
#!/bin/sh
g++ adder.cpp -fPIC -shared -o libdpi.so -I $CDS_INST_DIR/tools/inca/include
//-- switch add to ncsim
-sv_lib ./src/test_sv/libdpi.so
Run simulation and output:
ncsim: 05.83-s003: (c) Copyright 1995-2007 Cadence Design Systems, Inc.
snapshot worklib.top:module (SSS) is up to date (no update required).
Loading snapshot worklib.top:module .................... Done
ncsim: *W,NOLDPI: Unable to load ./src/test_sv/libdpi.so.
OSDLERROR: /cad/cadence/IUS583-s003-linux/tools.lnx86/lib/libgcc_s.so.1: version cannot open shared object file: No such file or directory or file is not valid ELFCLASS32 library..
ncsim: *F,NOFDPI: Function sum not found in any of the shared object specified with -SV_LIB switch.
ncsim: Memory Usage - 17.9M program + 10.4M data = 28.3M total
ncsim: CPU Usage - 0.0s system + 0.1s user = 0.2s total (1.0s, 15.8% cpu)
Best regards,
Davy
Originally posted in cdnusers.org by davyzhu
    Continue the last post:
    The sv file
    //---test_dpi_class.sv
    module top;
    int c = 1;
    int d = 2;
    int out;
    import "DPI-C" function int sum(input int a, input int b);
    initial begin
    out = sum(c, d);
    $strobe("out is %d\n",out);
    end
    endmodule
    And please add
    #include
    to the c++ file
    Best regards,
    Davy
    Posted By davyzhu on 4/26/2007 7:22 PM
    #!/bin/sh
    Best regards,
    Davy
    Did you check to see that this step was successful? Do a find . -name "libdpi.so" to see if this file got created.
    This seems to suggest that you are running the simulation in a dir different than the SO file got created. To make things simple, I would try running this in same dir or create a "link" to the SO file in current dir.
      The "find" command should be tried first to see if this file exists.
    Or this may also be an issue - are you running things on  same machine? Say linux or Solaris?
    Regards
    Ajeetha, CVC
    www.noveldv.com
    Originally posted in cdnusers.org by ajeetha
    Try setting you LD_LIBRARY_PATH env var as well. Either to "." or to the full path to where the libdpi.so resides.
    Insure that your libdpi.so is compiled for the same platform your simulation is running on (i.e. Linux or Solaris). If
    you would like a few small example - please drop me a line.
    Jim McGrath
    Originally posted in cdnusers.org by Jim McGrath
    Hi Ajeetha and Jim,
    I was on vacation last week and sorry for reply late.
    I have tried your methods, and found
    1. ./libdpi.so exist (I moved it to work dir)
    2. /cad/cadence/IUS583-s003-linux/tools.lnx86/lib/libgcc_s.so.1 exist
    3. Make sure libdpi.so is compiled for the same platform my simulation is running on.
    4. add work path to LD_LIBRARY_PATH
    But the simulation also failed and output the same error as previous post.
    Hi Jim,
    Could you please give out small example on C++ by DPI? Thanks in advance!
    Best regards,
    Davy
    Hi Jim,
    I have successfully pass a C by DPI example before. And the simulation environment is similar to the C++ by DPI example.
    Could you please give out your example or help to run my small example to make sure the tool is all right? Thanks a lot!
    Best regards,
    Davy
    Hi all,
    Anyone could help to demonstrate whether C++ by DPI do work or not?
    Any suggestions will be appreciated!
    Best regards,
    Davy
    Davy,
    With ncsim-5.83, i am able to use the large C++ reference design in my SV testbench.
    Infact, i am not only using the C++, but also has got the Matlab functions as well.
    The above adder example seems to be Ok. Do append extern "C" before the function which you are going to call through SV. That's it.
    Since, the work done being proprietary i am unable to write in detail. But DPI with C++ do work.
    -Vivek
    Originally posted in cdnusers.org by prasad_vc
    Hi Vivek,
    Thank you so much for the help and I will check my environment thoroughly.
    And I am very interested in Matlab function called by DPI, is there any reference given out by Cadence?
    Best regards,
    Davy
    Sorry to say, but no documentation is available for accessing the foreign language function through DPI, apart from C. The cadence support for the same was very bad, all they kept telling me is to use the new software from the matlab to be able to use the matlab function in SV tetbench through DPI.
    If you have any specific error, post here or mail me at prasad_vc@yahoo.com and i'll suggest the way to overcome the same.
    -Vivek
    Hi Vivek,
    Thanks a lot :)
    I have re-run the adder.cpp by DPI on IUS61. It seems ncsim can not find the libstdc++.so? Is this file provide by Cadence or a shared lib come with g++?
    IUS on SunOS:
    ncsim: *W,NOLDPI: Unable to load ./libdpi.so.
    OSDLERROR: ld.so.1: ncsim: fatal: libstdc++.so.2.10.0: open failed: No such file or directory.
    IUS on Linux:
    OSDLERROR: /cad/cadence/IUS61/lnx86/tools.lnx86/lib/libgcc_s.so.1: version `GCC_3.3' not found (required by /usr/lib/libstdc++.so.5).
    Best regards,
    Davy
