  2. Functional Verification
  3. HD AUdio Interface
  • Subscribers 66
  • Views 16113
HD AUdio Interface
archive over 19 years ago
Hi there
I am starting System Verilog now and I am looking for the best practice for designing a System verilog interface for the HD Audio bus as define by Section 5 of download.intel.com/.../HDAudio_03.pdf
This bus requires a master controller generating the clock, the reset and the frame sync, which drives up to 16 codec (slaves) getting the clock, the reset and the sync. I am wondering about the best way of using interfaces capabilities as mod ports and parameters to define a suitable intercae.
I am starting with this
interface hda_if  ();
  logic rstn;
  logic [15:0] sdi;
  logic sdo;  // bussed serial data output(s)
  logic bclk; // link 24.00-MHz clock
  logic sync; // 48 khz frame sync and outbound tag signal
  modport master (output rstn, output sync, output bclk, output sdo, inout sdi);
  modport slave (input rstn, input sync, input bclk, input sdo, inout sdi[0]);
  task init ();
    begin
      rstn = 0;
      sdo = 0;
      @(posedge bclk);
    end
  endtask
endinterface
- is it OK to define just sdi[0] in the slave modport ( a slave codec exposes just one SDI, while the master controller handles up to 16 SDI)? What about the other, unused sdi's?
- should I define the clock as an interface port - e.g.  interface hda_if (input blck); I see this is done in the SPI example of the System verilog traing, still I wonder how it works for master and slave flavours. The general question is how to handle clocks in interfaces for a master/slave bus: I probably don get the point of declaring interface ports .... SHould I use this stile and use modports
- what do you recommend about clock generation? Since he master is in charge to genreate bclk I wonder if it is preferred to add a clockgen in the interface decalration or in the master controller module only? e.g.
  default clocking bck_cb @(posedge bclk);
    default input #1 output #3;
    input sdi;
    output sdi;
    output sdo;
    output sync;
  endclocking
- The clockgen generates an istance right? So I suppose it is not receommended to include in the interface (I would inclued the interface declaration in a verilog file .vh included in a number of files using the i/f). do you recommend to put the interface in a compiled packege instead?
Sorry for this long email: I am eager to start with the right pace the project also fro a SW engineering standpoin
Any suggestion to fix/improve my approach is really welcome
Originally posted in cdnusers.org by marco.stanzani
