  2. Functional Verification
  3. 'class' not implemented??
  • Replies 7
  • Subscribers 66
  • Views 9187
archive over 19 years ago
Hi there
I am compiling a class getting
ncvlog: *E,SVNIMP (/prj/so_asic/USERS/STANZANI/SO_ASIC/CONFIG/../DIGITAL/SIMULATION/TBENCH/so_i2s.v,52|17): SystemVerilog construct not yet implemented:  compilation unit top scope declaration.
class so_i2s_layer;
I am using version
ncvlog -ver
TOOL:   ncvlog  05.83-p002
how can it be claimed 'system verilog support' if classes (a key feature for SV) is not usable?
thanks
Originally posted in cdnusers.org by marco.stanzani
    Hi Marco.
    At the moment, classes must be declared within a package, module or program.
    They're not permitted to "float" at the top level, hence the message you saw.
    I'd suggest you put any global classes into a package, and import that into whichever unit requires them.
    This makes for tidier encapsulation anyway :-)
    One last point, if you're using SystemVerilog, you'd do best to keep to the latest version, as that will have the best feature set. Currently the latest version is IUS6.1s2.
    Steve.
    Originally posted in cdnusers.org by stephenh
    Thanks Stephen
    agree that the ebst practice is to put them in a package. BTW it does not seems possible to define interfaces in a package as well (which is desirrable, IMO, sicne I'd put i a package everything that does not generate istances: right?)
    actually whe have just this version @Accent
    cheers
    FWIW: Interfaces are more like a module. They are instanced, etc and many tools even search for them like modules if you use the -y directive. So I would not think putting them in a package would be a good thing.
    Originally posted in cdnusers.org by bryan
    Posted By stephenh on 5/18/2007 6:42 AM
    Steve.
    Maybe it is worth adding that suggestion to the existing Error message as that would help the users in general a lot. How does one submit such "nice to have enhancement" if not via sourcelink? FWIW - I don't have sourcelink access as I'm not a NC customer but am running a verification services company in Bangalore.
    Regards
    Ajeetha, CVC
    www.noveldv.com
    Originally posted in cdnusers.org by ajeetha
    Hi Ajeetha.
    I'll file that enhancement request - it makes sense.
    If you're using Cadence tools when working for your clients, I guess the best thing is to get your client to file the service request under their SourceLink account ID. There may be an alternative way that you can file them directly, but I'm not aware of it.
    Regards.
    Steve.
    I filed enhance to improve error message. Thank you for the suggestion.
    Tim
    Originally posted in cdnusers.org by tpylant
    Thanks Tim & Steve, glad to see the quick action to make the tool easy to use, appreciate it!
    Cheers
    Ajeetha, CVC
    www.noveldv.com
