  2. Functional Verification
  3. randomize() question
  • Subscribers 66
  • Views 16365
archive over 19 years ago
Hi all,
There is a randomize() problem.
I want to randomize a Packet_seq which includes two Packet object.
First, I call Packet_seq randomize() to get pkt_seq. From pkt_seq to get Packet's cmd by constraint.
Second, I call Packet randomize() from Packet_seq's post_randomize() to make Packet's other attribute randomized.
But the random solver said there is a error when solve my constraint?
Any suggestions are welcome!
// Code listed below (and is attached)
module top;
typedef enum { WRITE=1,READ=2,IDLE=4} cmd_t;
typedef enum { WRITE_IDLE, READ_IDLE} packet_seq_t;
    class Packet;
        rand bit [7:0] addr;
        rand bit [31:0] data;
        cmd_t cmd;
        rand bit [2:0] dly;
        function new (cmd_t cmd_new = IDLE,
                      bit [31:0] data_new = 0,
                      bit [7:0] addr_new = 0,
                      bit [2:0] dly_new = 1);
            cmd = cmd_new;
            data = data_new;
            addr = addr_new;
            dly = dly_new;
        endfunction
        function void do_print ();
        begin
            $display("Packet_tr: cmd=%s, addr=%0d, data=%0d, dly=%0d", cmd.name(), addr, data, dly);
        end
        endfunction
   endclass : Packet
   class Packet_seq;
       rand packet_seq_t pkt_seq;
       Packet pkt[2];
       constraint pkt_seq_1_cst { pkt_seq == WRITE_IDLE -> (pkt[0].cmd == WRITE && pkt[1].cmd == IDLE); }
       constraint pkt_seq_2_cst { pkt_seq == READ_IDLE  -> (pkt[0].cmd == READ  && pkt[1].cmd == IDLE); }
       function new ();
           for (int i=0;i
               pkt[i] = new();
           end
       endfunction
       function void post_randomize();
           int random;
           for (int i=0;i
               random = pkt[i].randomize();
           end
       endfunction
           $display ("Packet Sequence is %s", pkt_seq.name());
           for (int i=0;i
               pkt[i].do_print();
           end
       endfunction
   endclass : Packet_seq
  // Main routain
  Packet_seq pkt_seq[3];
   initial begin
       int random;
       for(int i=0;i
           pkt_seq[i] = new();
           random = pkt_seq[i].randomize();
           pkt_seq[i].do_print();
       end
   end
endmodule
Originally posted in cdnusers.org by davyzhu
  • test_rand_sv.txt
    Davy,
         What you are looking for is so called "E-Sequences" or in SV, it is better called "Scenarios" (as the term sequence is used inside SVA domain). Having said that, the way you are approaching does seem the best/optimal way to me atleast. You should try using an array of "Pkt_Cmd" and use SV's "foreach" constraints. Now I'm not sure of tool support for this in your tool set, check with the vendor. We showed how to build a custom scenario for a Vending machine example in our VMM adoption book (www.noveldvocm or www.systemverilog.us). To be honest and fair, it is not that trivial to do this. eRM has sequences precisely for this and perhaps equivalent exists in URM. FWIW, VMM scenario does precisely this and you get this in few lines of code.
    I know I didn't give you direct answer, but hopefully a right direction.
    Good Luck
    Ajeetha, CVC
    www.noveldv.com
    Originally posted in cdnusers.org by ajeetha
    Sorry, forgot to add that calling randomize() inside post_randomize is a bad style, avoid it if you can
    Ajeetha, CVC
    www.noveldv.com
    Hi Ajeetha,
    I have solve the problem by just add rand to Packet object and use randomize only one time at pkt_seq[i].randomize().
    Bests regards,
    Davy
