  2. Functional Verification
  3. Task implementation outside module or class?
  • Subscribers 66
  • Views 16664
archive over 19 years ago
Hello , Is it possible to decalre Tasks in a seperate file (without module or class) and use the task in a program or module. task.sv: File name ------------------ task test; $display ("In task"); endtask test.sv: Filename ------------------ program test(Interface) `include "task.v" initial test endprogram Inorder to accomodate above implementation what changes to be made in the code. Thanks in advance. Thanks & Regards, Quest Team
Originally posted in cdnusers.org by sundar_80
    i think u may have to import the module or package in which the program exists...
    import::
    this enables u to use all the module properties.... (data types ,functions, tasks.. etc)
    Originally posted in cdnusers.org by catchraghu
    You can declare tasks (and functions) in a SystemVerilog package. The package contents can then be imported, one-by-one or with a wildcard, into any program or module. This is a cleaner solution than using Verilog `include. e.g.
    //simple_package.sv
    package simple_package;
       task test();
          $display("This is a test\n");
       endtask // test
    endpackage // simple_package
    //simple_program.sv
    program simple();
       import simple_package::test;
       initial
         begin
            $display("Calling test..");
            test();
         end
    endprogram // simple
    The command "irun *.sv"  generates the following output:
    Calling test..
    This is a test
    Dave
    Originally posted in cdnusers.org by dl_doulos
