  2. Functional Verification
  3. memory leak - IUS61 system verilog
  • Subscribers 66
  • Views 2633
archive over 19 years ago
I have a small piece of code that uses the class and mailbox feature of system verilog.  There is a sender task which generates a transactions and puts the transaction handle in a mailbox.  The receiver task waits on a message from the mailbox and when one arrives it reads the message and print a message.  The mailbox is bounded.
The sender and receiver tasks are forked in an initial block.
I seem to be experiencing a memory leak since the heap continues to grow.  My understanding is system verilog handles garbage collection automatically.
What am I doing wrong in my code.  Attached is code:
module mem_leak ();
// Generate clock and reset
reg clk;
initial
begin
    clk = 0;
    forever #(10/2) clk = ~clk;
end
// Class declarations
class CpuCmd;
    time startT;
    time stopT;
    reg [1:0] cpu_id;
    reg btype;
    rand reg wr_rdn;
    rand reg [26:0] addr;
    rand reg [ 5:0] size;
    reg [39:0] packed_cmd[1:0];
    reg [10:0] total_wd;
    extern task gen_cpu_addr;
    constraint cpucmd_constraint;
endclass
constraint CpuCmd::cpucmd_constraint
    addr inside {[0 : 2000]};
    size inside {1, 4};
task CpuCmd::gen_cpu_addr;
    startT    = $time;
    stopT     = startT;
    cpu_id    = 0;
    btype  = 0;
    packed_cmd[0] = {btype,wr_rdn,3'h0,addr,2'h0,size};
    packed_cmd[1] = 40'h0;
    total_wd = size;
endtask
// Declarations
// Command queue to hold transactions
mailbox cmdQ;
// Main client loop
initial
begin
    repeat (20) @(posedge clk);
    cmdQ  = new(4); // bounded mailbox
    fork
        begin
            $display("INFO: Fork Sender");
            sender;
        end
        begin
            $display("INFO: Fork receiver");
            receiver;
        end
    join
end
// Sender
task sender;
   int val;
   CpuCmd Scmd;
   while (1)
   begin
    repeat (1000) @(posedge clk);
    Scmd = new;
    val = Scmd.randomize();
    if (val == 0)
    begin
        $display("Scmd randomization failed at %0t", $time);
        @(posedge clk);
        $finish;
    end
    Scmd.gen_cpu_addr(); // generate a command
    cmdQ.put(Scmd); // put command into mailbox
    $display("Sent message at %0t", $time);
   end
endtask
// Receiver
task receiver;
   CpuCmd Rcmd;
   while (1)
   begin
           @(posedge clk);
        cmdQ.get(Rcmd); // Get a message from the mailbox
        $display("Received message at %0t", $time);
   end
endtask
endmodule
Originally posted in cdnusers.org by vietnguyen
    What exact version of IUS are you using?
    I tried running your code on IUS6.11s2 and 6.11s3, but didn't see any sign of increasing memory consumption.
    My tests ran for about 1.5h and passed hundreds of thousands of items through the mailbox.
    Maximum memory consumption was always 29.3 MB no matter how long the test ran for.
    Originally posted in cdnusers.org by stephenh
