  2. Functional Verification
  3. Declaring class outsside program block
  • Subscribers 66
  • Views 17243
archive over 19 years ago
Hello, Is it possible to declare class outside the program block like bellow? class gen; endclass program test; endprogram;
Originally posted in cdnusers.org by sundar_80
    Sorry for my earlier code for not following the rules, i have correct the format of the code now. class gen; endclass program test; endprogram; Sundar
    Sundar,
     >> Is it possible to declare class outside the program block like bellow?
    Yes, language allows it though I personally discourage it - atleast encapsulate them under packages. I know some debug tools today work best if classes are declared inside program.
    HTH
    Ajeetha, CVC
    www.noveldv.com
    Originally posted in cdnusers.org by ajeetha
    Hello Ajeetha,
    Thanks a lot for your mail, as you mentioned its always better to encapsulate it in package, i also feel that's the good practice.
    But one query, if a class is encapsulated inside package is it possible to use the class itself, as far my knowledge about SV(i have very little knowledge) only task defined in the package can be used not the class is that correct?
    Sundarraj
    Hi Sundar,
    You can encapsulate the class inside a package and whenever you want to use this class, just "import" that package. You can import the package using following
    import ::*;
    then you can easily use the class and its all properties and methods which were declared in that package.
    regards
    Jagvin
    Originally posted in cdnusers.org by jagvinder
    The command for importing the package is
    import package_name::*;
    sorry, i missed it in last mail.
    regards
    Jagvinder
    Hello Jagvinder,
    Thanks a lot for your mail. I will try to use as you mentioned.
    Sundarraj
