  2. Functional Verification
  3. Coverage of Enum Type Bins
  • Subscribers 66
  • Views 20040
archive over 19 years ago
I have an issue while taking coverage of enum type bins.
I am using IUS 6.1. While compilation, warnings are coming for enum type bins.
Let me share the peice of code with you.
//TO SELECT FROM HALF DUPLEX OR FULL DUPLEX MODE OF TRANSMISSION
typedef enum {HALF, FULL } transmission_mode_t;
transmission_mode_t transmission_mode_cov;
covergroup packet_rxd @(packet_collected);
    HALF_DUPLEX_MODE_N: coverpoint transmission_mode_cov
 bins HALF_DUPLEX_N = {HALF};
    FULL_DUPLEX_MODE_N: coverpoint transmission_mode_cov
        bins FULL_DUPLEX_N = {FULL};
endgroup
packet_rxd_cg packet_rxd_instance = new();
The warning which is coming is
ncelab: *W,CUVBVE (/home/coverage.sv,146|26): Bin value type mismatch with coverpoint type.
ncelab: *W,CUVBVE (/home/coverage.sv,151|33): Bin value type mismatch with coverpoint type.
This issue was not there with NCSIM 5.8.
Please help me to resolve this issue.
Regards
Jagvin
Originally posted in cdnusers.org by jagvinder
    I ran your code in IUS5.83 and IUS6.11 which both worked. I don't have access to IUS6.1, so I can't verify your problem there, but since it works on IUS6.11, I'd advise to go ahead and download the latest version.
    IUS0611USR4
    , Version: 06.11-s004 was just released this week, so it is a good time to download, especially if you are using the IUS low-power (CPF) capabilities.
    Tim
    Originally posted in cdnusers.org by tpylant
    Thanks Tim,
    but i am facing a serious issue while merging the functional coverage for my model.
    Is it because of these warnings for enum type bins???? or somewhat else??????
    While merging, it is giving some "checksum mismatch error". Although i am not changing my env at run-time, the error is coming.
    Jagvin
    I tried all possible combinations of mixing enums and randomization. The only way I could get the coverage loading to fail is if I modified the code. I was using IUS6.11-s002.
    Tim
