  2. Functional Verification
  3. array initialization-1b (system-verilog)
  • Subscribers 66
  • Views 16117
archive over 19 years ago
Using the IUS 5.83 version, I'm trying to
compile these simple SV code lines:
parameter    ports_num                  = 4;      // ports number
integer px_num[ports_num-1:0]    // pixel num x port
initial
begin
  px_num[ports_num-1:0] = {default:4'h6};
end
and I got the following errors
file: /IPREUSE/DATABASE/INTERNAL/DIG/INPROGRESS/gborgo/simd_A0_a/config/../generic/rtl/svlog/shm.v
ncvlog: *E,ILLPRI (/IPREUSE/DATABASE/INTERNAL/DIG/INPROGRESS/gborgo/simd_A0_a/config/../generic/rtl/svlog/shm.v,119|33): illegal expression primary [4.2(IEEE)].
        module simd.shm:v
                errors: 1, warnings: 0
Is it a problem of the IUS 5.83 version ?
BR
Giampiero Borgonovo
Originally posted in cdnusers.org by borgonov69
    The error is caused because you used specified a range on the assignment after already declaring the type. You have two choices for the fix.
    integer px_num[ports_num-1:0] = '{default:4'h6}; or integer px_num[ports_num-1:0] initial begin px_num = '{default:4'h6}; end
    For more examples, refer to IEEE1800, sec 8.13.
    Tim
    Originally posted in cdnusers.org by tpylant
    This solution solves the syntax issue.
    The issue is originated by the Esperan System verilog for designers manual (version 2.7) that I'm using
    as reference.
    Thanks.
    BR
    Giampiero
