  2. Functional Verification
  3. Hierarchial Access of Class Objects
  • Subscribers 66
  • Views 15367
archive over 19 years ago
Hi all,
I am trying to access the method in my class hierachially. But the tool is reporting that hierarchial access to dynamic objects is not supported. I am using LDV5.8. Which version of the LDV supports SV properly. Does I need to have any special licence to upgrade from one version to other.
Sreenivas
Originally posted in cdnusers.org by vaas_m
    Hi Sreenivas
    Which exact version of IUS are you using (paste the results of "ncsim -version")?
    I tried the following example in IUS 5.83s9 and in IUS 6.11s3 and it works fine.
    If this example isn't close enough to what you're trying, please can you paste a better description of the problem?
    module tb; class a_c; rand int a; task print; $display("%m : a_c.a == %d", a); endtask endclass class b_c; rand a_c a_i; task print; if (a_i != null) a_i.print(); else $display("Cannot print a_i - it is null"); endtask endclass class c_c; rand b_c b_i; task print; if (b_i != null) b_i.print(); else $display("Cannot print b_i - it is null"); endtask endclass c_c c_i = new; initial begin c_i.b_i = new(); c_i.b_i.a_i = new(); c_i.print(); c_i.b_i.a_i.print(); end endmodule
    Originally posted in cdnusers.org by stephenh
    Hi Steve,
    I am using LDV 5.83-p003. I have a verilog module in which my classes are defined. When I am trying to call the methods of my the classes I am getting an error. (Ex: tb.U_model.class_obj.task_name )
    Posted By vaas_m on 9/03/2007 3:06 AM
    Hi Steve,
    Srinivas,
       My guess is that you have not constructed the class object before calling the task. Can you take Steve's example code and modify as per your need and see if you can reproduce the problem? As far as I see it should work - provided the class objects are new'ed before calling tasks.
    Cheers
    Ajeetha, CVC
    www.noveldv.com
    Originally posted in cdnusers.org by ajeetha
