  2. Functional Verification
  3. elaboration internal error (IUS61)
  • Subscribers 66
  • Views 17983
archive over 19 years ago
I'm compiling and elaborating a very simple SV code, attached as svlog01.tar.gz file.
Following the compilation and elaboration code.
I got internal error for any top level design I tried to elaborate, while the compilation is error free.
Is there any issue in the compilation/elaboration flow or other (coding issue, tool issue) ?
The IUS61 versions has ben used.
BR
Giampiero
compilation/elaboration commands
ncvlog -SV -IEEE1364 -WORK $LIB $MESSAGES $SIMD_VLOG/simd_pack.v -log $LOG/ncvlog.log -append
ncvlog -SV -WORK $LIB $MESSAGES $SIMD_VLOG/swfabr.v -log $LOG/ncvlog.log -append
ncvlog -SV -WORK $LIB $MESSAGES $SIMD_VLOG/shm.v -log $LOG/ncvlog.log -append
ncelab -log $LOG/ncelab.log -work $LIB -MESSAGES -NOCOPYRIGHT -NOWARN CUDEFB -UPDATE -snapshot swfabr $LIB.swfabr
ncelab -log $LOG/ncelab.log -work $LIB -MESSAGES -NOCOPYRIGHT -NOWARN CUDEFB -UPDATE -snapshot shm $LIB.shm
log file
Compiling SIMD package ...
file: /IPREUSE/DATABASE/INTERNAL/DIG/INPROGRESS/gborgo/simd_A0_a/config/../generic/rtl/svlog/simd_pack.v
        package simd.simd_pack:v
                errors: 0, warnings: 0
..done
Compiling SWFABR component...
file: /IPREUSE/DATABASE/INTERNAL/DIG/INPROGRESS/gborgo/simd_A0_a/config/../generic/rtl/svlog/swfabr.v
        module simd.swfabr:v
..done
Compiling SHM component...
file: /IPREUSE/DATABASE/INTERNAL/DIG/INPROGRESS/gborgo/simd_A0_a/config/../generic/rtl/svlog/shm.v
        module simd.shm:v
..done  Elaborating the design hierarchy:
        Building instance overlay tables: .................... Done
        Generating native compiled code:
                simd.simd_pack:v
                        streams:  11, words:  4319
                simd.swfabr:v
ncvlog_cg: *F,INTERR: INTERNAL ERROR
The tool has encountered an unexpected condition and must exit.
Contact Cadence Design Systems customer support about this
problem and provide enough information to help us reproduce it,
including the logfile that contains this error message.
  TOOL: ncvlog_cg       06.10-p001
  HOSTNAME: kane
  OPERATING SYSTEM: Linux 2.4.21-4.ELsmp #1 SMP Fri Oct 3 17:32:58 EDT 2003 x86_64
  MESSAGE: gq_primaryobjectclass - illegal vxt_class (629)
ncelab: *E,CUVCGF: Code generation for simd.simd_pack:v failed.
                simd.swfabr:v
  HOSTNAME: kane
ncelab: *E,CUVCGF: Code generation for simd.swfabr:v failed.
ncelab: *F,CGFAIL: Code generation failed for one or more modules.
ncelab: *F,INTERR: INTERNAL ERROR
  TOOL: ncelab  06.10-p001
  HOSTNAME: kane
  MESSAGE: tl_expr_count - expr type 629
Originally posted in cdnusers.org by borgonov69
svlog01.tar.gz
    Any internal error is a serious problem and should be reported to Cadence Customer Support. You have a nice small testcase here, so they should be able to take care of it easily.
    The problem appears to be in the assignments:
    assign rdata_shram = (oen_shram == 0) ? shm_read : '{'bz};
    and
    shm_read = '{'bx};
    Apparently this '{'bz} syntax is ok (at least it gets by ncvlog), but I've never seen it used before. For unsized bit constants, I've always used 'z or 'x.
    assign rdata_shram = (oen_shram == 0) ? shm_read : 'z;
    shm_read = 'x;
    Originally posted in cdnusers.org by TAM
    Thanks for the fixing of the file shram.v. The problem is the construct '{}.
    It works also with the construct 'bz or 'bx.
    In the file swfabr.v, Isolved the issue fixing the code as following described.
    always_comb
    if(mask_gnt)
    gnt = '{default:'b0};
    else
    gnt = i_gnt;
    //assign gnt = (mask_gnt == 1) ? ('{default:'b0} ): i_gnt;
    Thanks again.
    Giampiero
    I don't have 6.10-p001, but I will say that the swfabr.v file compiles and elaborates fine for me with 6.11-s003.
