  2. Functional Verification
  3. $fgets function issue & soluition(IUS61)
  • Subscribers 66
  • Views 3064
archive over 19 years ago
I discovered that the system task fgets doesnt work correctly (return a single char and not the full line) if the first argument is defined as:
string line;
Replacing the line definition as following:
reg[MAXL-1:0] line;
the fgets works correctly.
Following the piece of code used.
      while ($fgets(line,ptr) != 0)
      begin
//        $display("dbg: line => %s ",line);
        r = $sscanf(line,"%s %x %x %x \n", label,addr,data,mask);
        if (label != "//")
          break;
      end
Is it an implemenation issue (IUS61) of the fgets system task ?
BR
Giampiero
Originally posted in cdnusers.org by borgonov69
    Currently, IUS does not support string datatype as an argument to $fgets. However, it does
    support string datatype for $fscanf. eg:
    string linebuf;
    int fd, ret;
    ret = $fscanf(fd,"%s",linebuf);
    Tim
    Originally posted in cdnusers.org by tpylant
