  2. Functional Verification
  3. array of parameters issue (IUS61)
  • Subscribers 66
  • Views 17483
archive over 19 years ago
1) I found the following issue about the initialization of an array of parameters:
package simd_pack;
  parameter    ports_num                           = 4;       // ports number
  parameter    [ports_num-1:0]px_num      = '{ports_num-1:8,default:4};    // pixel num x port
endpackage : simd_pack
when I print the values of the array I got:
INFO: px_num 0
INFO: px_num 0
INFO: px_num 0
INFO: px_num 0
Is it  an issue of the IUS 06.11-s004 version ?
2) If I use the following definition:
integer    px_num[ports_num-1:0]      = '{ports_num-1:8,default:4};    // pixel num x port
then  it works
INFO: px_num           4
INFO: px_num           4
INFO: px_num           4
INFO: px_num           8
but in this case I cannot pass the array element as parameter to a module, because I got the following
error:
    swf_bfm #(.port_id(i),.pxn(px_num[i]))  u_swf_bfm (
ncelab: *E,NOTPAR (../tbench/tb_swf.v,157|38): Illegal operand for constant expression [4(IEEE)].
3) If I define the array as unpacked array, I got the known IUS limitation:
parameter    px_num [ports_num-1:0]     = '{ports_num-1:8,default:4};    // pixel num x port
ncvlog: *E,SVARPA (/IPREUSE/DATABASE/INTERNAL/DIG/INPROGRESS/gborgo/simd_A0_a/generic/rtl/svlog/simd_pack.v,21|20): Unpacked array and string parameters are currently not supported.
How can I solve the following issue ?
I'd need  to define an array of constants and to pass a single element of the array as parameter
of a module.
BR
Giampiero
Originally posted in cdnusers.org by borgonov69
    1) parameter [ports_num-1:0]px_num = '{ports_num-1:8,default:4};
    is a packed array, therefore the intialization above doesnt make sense.
    This is the solution:
    parameter logic [ports_num-1:0][7:0]px_num = '{ports_num-1:0,default:4}; // pixel num x port
    I have the headache to work with the packed array, when unpacked array (3) shall be the natural solution.
    Giampiero
    Just as a follow-up.
    The declaration "parameter [ports_num-1:0] px_num;" isn't either a packed or unpacked array of parameters. It is a single parameter "px_num" whose width in bits is being set to "ports_num". That is certainly how Verilog 2001 interprets it and I would expect that SystemVerilog remains backward compatible.
    I don't know how the initializer "'{ports_num-1:8,default:4};" would be interpreted in that context. I imagine that it assigns each bit in the single parameter "px_num" to the given value. Since each initializer has its low order bit = 0, all "ports_num" bits of the single parameter were set to 1'b0.
    Originally posted in cdnusers.org by TAM
