  2. Functional Verification
  3. A question about randomize()
  • Subscribers 66
  • Views 15583
archive over 19 years ago
In the following code,  when BCDA.randomize() is excuted, it seems to me methd ADD() is also excuted at same time even though it is not explicitly called. How does randomize() work exactly? Thanks in advance!
//BCD addition testbench
//www.asichowto.com
module BCDAddition_tb();
class BCDAdd;
    rand logic[3:0] BCD1,BCD2;
    logic[7:0] result;
    function new();
        BCD1=0;
        BCD2=0;
    endfunction
    constraint c
        BCD1
        BCD2
    function void ADD();
        result=BCD1+BCD2;
        if(result>9)
           result=result+6;
    endfunction
endclass
BCDAdd BCDA;
logic[3:0] b1,b2;
logic[7:0] r;
BCDAddition U(b1,b2,r);
initial
begin
    repeat(10)
    begin
        BCDA=new;
        if(BCDA.randomize())
        begin
            b1=BCDA.BCD1;
            b2=BCDA.BCD2;
//            BCDA.ADD();
            if(r!=BCDA.result)
            begin
                $display("Class:  BCD1=%d BCD2=%d result=%d", BCDA.BCD1,BCDA.BCD2,BCDA.result);
                $display("Module: BCD1=%d BCD2=%d result=%d", b1,b2,r);
            end
        end
        #10ns;
    end
end
endmodule
Originally posted in cdnusers.org by jt27560
    Why do you think ADD() is called?
    I don't see anything that calls it explicitly (ignoring the commented out line).
    I pasted this code into a file and it ran without calling ADD()...
    Originally posted in cdnusers.org by stephenh
    Thanks, Steve.
    It does not display anything whether I comment out BCDA.ADD() or not, which gives me an impression that ADD() is executed too when randomize is executed.
    I should use !== instead of !=. And should put a delay right after ADD();
    In your example above, ADD is not called unless it is called specifically via the BCDA.ADD() function call. What's happening in your code is that the begin/end block after calling randomize() executes to completion before the BCDAddition() module instance is evaluated so you are getting strange results. If you put a delay after the b1/b2 assignments, you will get the expected behavior.
    I hope this helps.
    Kathleen
    Originally posted in cdnusers.org by kameade
