  2. Functional Verification
  3. Packing of Random variables into List of bytes
  • Subscribers 66
  • Views 16257
archive over 19 years ago
Example:
// class -1
  class fc_field;
    rand bit [1:0] protocol_ver;
      constraint pro_ver {
          protocol_ver == 0;
    rand bit [1:0] pkt_type;
      constraint Pkt_type {
          pkt_type == 2;
    rand bit [3:0] pkt_sub_type;
      constraint Pkt_sub_type {
          pkt_sub_type == 11;
    rand bit to_ds;
      constraint To_ds {
          to_ds == 0;
    rand bit from_ds;
      constraint From_ds {
          from_ds == 0;
    rand bit more_fragment;
      constraint More_fragment {
          more_fragment == 0;
    rand bit retry;
      constraint Retry {
          retry == 1;
    rand bit pwr_mgmt;
      constraint Pwr_mgmt {
          pwr_mgmt == 0;
    rand bit more_data;
      constraint More_data {
          more_data == 0;
    rand bit protected_frame;
      constraint Protected_frame {
          protected_frame == 1;
    rand bit order;
      constraint Order {
          order == 1;
  endclass
// Class-2
  class seq_control_field;
    rand bit [3:0] fragment_number;
      constraint Fragment_number {
          fragment_number == 0;
    rand bit [11:0] sequence_number;
      constraint Sequence_number {
          sequence_number == 0;
  endclass
// Main Class. This instantiates the fc_field and seq_control_field class objects
  class mac_header;
    rand fc_field fc_obj = new();       // Object of fc_field
    rand bit [15:0] duration_id;
      constraint Duration_id {
          duration_id == 0;
    rand bit [47:0] address_1;
      constraint Address_1 {
          address_1 == 48'h001122334455;
    rand bit [47:0] address_2;
      constraint Address_2 {
          address_2 == 48'h009988776655;
    rand bit [47:0] address_3;
    rand seq_control_field seq_obj = new();      // Object of fc_field
    rand bit [47:0] address_4;
    rand bit [15:0] qos;
      constraint Qos {
          qos == 16'h0000;
  endclass
In the above example, how can i pack the mac_header into list of bytes? This shouldn't affect the constraints on the class member functions, of all the threee different classes.
Also, is there any way to print the class object?
All of the above can be done eeasily in specman, is it possible in the systemverilog implicitly?
-Vivek Prasad
Originally posted in cdnusers.org by prasad_vc
    For packing you can use bit-streaming operator. I didn't try on your code, but it works as below:
    program pack_pgm; class mac_header; .. mac_header mac_header_0; byte byte_array []; initial begin : test mac_header_0 = new(); byte_array = {byte << {mac_header_0}}; end : test
    I know some tools allow it as part of regular $display. But I generally find it is much better to write your own do_print () method - so that you have your design specific format. This brings in consistency for the whole team - for a small price (of maybe 20 lines of typing).
    HTH
    Ajeetha, CVC
    www.noveldv.com
    Originally posted in cdnusers.org by ajeetha
    Ajeetha,
    Thanks for the same.
    NCSim is giving error for that statement. "Illegal Expression Primary".
    I am attaching the code. Can you help me?
    -Vivek
    mac_mpdu.tar.gz
    I would imagine that may be Unsupported in your version. Write a simple function to to the pack - make it hierarchical - each class will pack its own contents and the derived classes would simply use the super.pack() and build on it.
    HTH
    Ajeetha, CVC
    www.noveldv.com
    Which Tool and Version are you referring to?
    I am using the ncsim 6.1ius-s002.
    -Vivek
