  2. Functional Verification
  3. ncvlog -sv and ports of type "real"
  • Subscribers 65
  • Views 4554
archive over 18 years ago
Hi there,
For some system modeling I am looking into using ncvlog in SystemVerilog mode (ncvlog -sv) since I understand from some online documentation (www.deepchip.com/.../0466-04.html) that in SystemVerilog real data types can be passed hierarchically through ports.
Here is my test code:
    module test(input real x);
    endmodule
with the following result:
    ncvlog -sv test.v
    ncvlog: 06.11-s004: (c) Copyright 1995-2007 Cadence Design Systems, Inc.
    ncvlog: *E,SVNTRL (test.v,1|23): A module port that is a net cannot be of type 'real' by         SystemVerilog language rules.
My questions are:
- does ncvlog -sv support real port types?
- are real port types indeed allowed in SystemVerilog by standard?
I am aware of the regular "workaround" using 64-bit vectors and $realtobits etc. but I was hoping to be able to use something more convenient.
Axel
Originally posted in cdnusers.org by schuur
    Try using the keyword 'var' in the port list
    // ncverilog real_io.sv +sv +linedebug +gui &
    module top();
    real rrr;
    one U1(rrr);
    two U2(rrr);
    endmodule
    module one(input var real rrr);
    initial
    #0 $display("%m %f", rrr);
    endmodule
    module two (output real rrr);
    initial
    rrr = 3.14159;
    endmodule
    Originally posted in cdnusers.org by tmackett
    Indeed that does the trick.
    Thanks very much - it was hard to find this information otherwise.
