  2. Functional Verification
  3. Template classes with ncvlog 6.2
  • Subscribers 66
  • Views 15698
archive over 18 years ago
Hi, When I use ncvlog -sv to compile the following I get errors: class a#(int width=5); bit[width-1:0] c; endclass I've been told that compiling template classes with ncvlog is possible using a pre-compilation script (the way it used to be done with C++). Is that true? if yes, where can I get the script and how do I run it? best, Avidan
Originally posted in cdnusers.org by avidan_e
    What errors are you getting? Maybe parameterized class is not yet supported?
    Ajeetha, CVC
    www.noveldv.com
    Originally posted in cdnusers.org by ajeetha
    Hello Avidan,
    Parameterized classes are supported in IUS6.1 and IUS6.2 using the -svpp command-line option to irun. The irun executable is able to recognize Verilog, SystemVerilog, SystemC, e and C/C++ files based on their file extension. If you are willing to use irun instead of "ncverilog" or ncvlog/ncelab/ncsim - it will be easy for you to use the parameterized class capability. Here is a small example I ran on IUS6.2:
    module test;
    class abc #(int width=8);
    rand bit [width-1:0] data;
    endclass : abc
    abc #(4) my_class = new(); // width = 4
    abc #() my_class2 = new(); // syntax for default width of 8
    initial begin
    void'(my_class.randomize()):
    void'(my_class2.randomize());
    $display(my_class.data,,my_class2.data);
    end
    endmodule : test
    To run this example: % irun -svpp test.sv
    I hope this helps.
    Kathleen
    Originally posted in cdnusers.org by kameade
    Hi Kathleen,
    >> if you're wiling to use irun...
    irun, iraq whatever it takes to compile the thing I don't mind :-)
    Thanks a lot, it works...
    Avidan
