  2. Functional Verification
  3. Simple example of passing classes between nc and Specma...
  • Subscribers 66
  • Views 17730
Simple example of passing classes between nc and Specman
archive over 18 years ago
Hi, I would like to pass Specman structs to SV classes and back, using NC. I know that's possible because I'm able to run the MRM demo. However, I'm looking for a simpler example with a simple compile script...I've tried to compile the attached files (e2sv_class.e, e2sv_class.sv, taken from Specman help, beta features, 2.6) using the attached compile script (taken from 2.9 and slightly modified), but that doesn't seem to work. Can anyone indicate what's the right way to compile these files? thanks, Avidan
Originally posted in cdnusers.org by avidan_e
e2sv_class.tar.gz
    Interesting trial indeed. I must admit I don't know the answer really, but looking at the code I see that your E-struct name is "dut_instruction" whereas inside SV you have:
    import specman_types::*; sn_dut_instruction ins;
    Is this how it is supposed to be as per manual? Or is it a typo?
    Also can you elaborate on what you mean by:
    <quote>
    </quote>
    Ajeetha, CVC
    www.noveldv.com
    Originally posted in cdnusers.org by ajeetha
    Hi Ajeetha,
    Thanks for your answer.
    The example was copied as is from:
    http://sourcelink.cadence.com/docs/files/Release_Info/Docs/sn_beta/sn_beta6.1/sn_beta.pdf
    pages 35-36.
    I believe the name mismatch is due to the fact that in between the e code and the sv code, you have the automatically generated stubs file, that probably fiddles a bit with the type names, and prefixes them with "sn_"
    "that doesn't seem to work" is in fact too general...it means that the automatically generated stubs file (specman.svh) gives compilation errors when compile with ncvlog -sv.
    Avidan
    Hi Avidan
    We couldn't recreate your compilation error, we've ran the attached script, and it passed compilation phase.
    Which Specman and IUS versions do you use?
    Also, please attach the ncvlog.log file that is created when you try to compile the specman.svh file.
    Erez
    Originally posted in cdnusers.org by erezb
    Hi Erez, I'm using Specman and ncvlog 6.20. The script output and the ncvlog.log file are attached. Best, Avidan
    • ncvlog.txt
    Hi Aviad
    It seems that the INCA_libs already includes some of the SV environement generated by Specman.
    (Have you ran this example also with irun ?)
    Delete the existing INCA_libs, and rerun the compile script.
    Erez
    Hi Erez,
    Thanks, you're right. It works now.
    Avidan
