  2. Functional Verification
  3. Connecting outputs of type "real"?
  • Subscribers 66
  • Views 8279
archive over 18 years ago
For a system modeling task with sytemverilog, I have various blocks that have outputs of type "real". To match the hardware being modeled (an analog circuit), these outputs need to be connected together. Only one of these blocks would have valid outputs at one time, the others would have a high-impedance ("z") value.
However, there seems to be some fundamental problem with connecting module outputs of type "real" together, since variables cannot have multiple drivers, and "real" data types are variables.
Here is a test case and the result:
module test1;
    real a;
    real b;
    initial
    begin
        a = 0.0;
    end
    test1a t1(.A(a),.B(b));
    test1a t2(.A(a),.B(b));
endmodule
module test1a(A,B);
    input var real A;
    output var real B;
    always @(A)
        B = A;
endmodule
> ncverilog +sv test.v
ncverilog: 06.11-s004: (c) Copyright 1995-2007 Cadence Design Systems, Inc.
file: test.v
        module worklib.test1:v
                errors: 0, warnings: 0
        module worklib.test1a:v
                Caching library 'worklib' ....... Done
        Elaborating the design hierarchy:
ncelab: *E,MULDRV (./test.v,12|18): Multiple drivers to variable b detected.
ncverilog: *E,ELBERR: Error during elaboration (status 1), exiting.
Does anyone have an idea on how to solve this?
Thanks!
Axel
Originally posted in cdnusers.org by schuur
    Not sure if it it legal for real but wire instead of var is the correct net_type to do this for "logic". "Var" is only single source and "wire" allows multiple sources.
    Originally posted in cdnusers.org by bryan
    wire can't be real. Use $realtobits with wire[63:0].
    Originally posted in cdnusers.org by shalom
    That is, wire [63:0].
    Posted By shalom on 12/09/2007 2:22 AM
    Last try: wire [ 63 : 0 ].
