  2. Functional Verification
  3. Copy an array
  • Subscribers 66
  • Views 15092
Copy an array
archive over 18 years ago
Hi, For some reason my postings all show up as one single line. Any idea why? If you would like to read this normally have a look at the attached text file. I'm trying to copy an array from one class instance to another, but keep getting compilation errors everywhere I go. Please have a look at the code below: package t; class yy; int a[$]; endclass class x; int b[$]; yy y1; function u(); // option 1 : doesn't compile b = y1.a; // option 2 : doesn't compile foreach (y1.a[i]) b.push_back(y1.a[i]); // option 3 : compiles but I really wish I don't have to use it each time I want to copy an array! for (int i=0; i
Originally posted in cdnusers.org by avidan_e
  • for_cdnusers.txt
    Check out the second posting on this forum (http://www.cdnusers.org/Forums/tabid/52/forumid/66/postid/4806/view/topic/Default.aspx). It explains how to post code so that it will appear correctly.
    Tim
    Originally posted in cdnusers.org by tpylant
