  2. Functional Verification
  3. Modularization of SystemVerilog
  • Replies 12
  • Subscribers 66
  • Views 25513
archive over 18 years ago
Hi guys,
I have an question concerning modularization, but I have not found it in one of the following books: "Writing Testbenches using SystemVerilog" and "SystemVerilog for Verification". So, I hope you can help me.
I have written much classes, which are all in ONE file so far, but this is not the target state I wish for this project. The problem is, that for example, one class instantiates another class and I don't know, how to separate the classes.
Is a mechanism available, as C-Header-Files?
I hope you can help me, because several smaller files are much better than one singe huge file.
Thanks for your help!
If the answer should be in one of the itemized books, please sorry, I haven't found it!
Sebastian
Originally posted in cdnusers.org by sebastian
    Thank you very much for your good advices, tpylant.
    Next question is, where to store the source file for the interfache. I've already found the error messages I get, here in the forum but they don't really help me.
    I will describe, the files I have so far:
    One package which contains all my classes. The classes are all stored in separate files and included in the package. The program containing my testbench, includes the package with the import command. So far, so good.
    I have then a topmodule, which contains the source of the interface and the toplevel module (as described by tpylant above). Furthermore I've written a simple testmodule which "simulates" the real device (actually only tests if interface is working).
    But I don't know how to compile these files and nobody around me can help.
    Because of this fact, I hope, you will help me. So far, my "makefile" looks like the following:
    #! /bin/csh -f
    ncvlog -mess -status -sv pkg.sv env_prog.sv
    ncelab -mess -status -snapshot TEST env_prog
    ncsim -mess -status TEST
    pkg.sv contains the include-commands of the different classes and env_prog contains the program (not the toplevel module).
    Again, thanks for your help!
    Sebastian
    Ok. this problem is solved, I've got same other problems with simulation, but I think the infrastructur itself is ok. To avoid an infinite thread not related with the base topic any more, I will begin a new thread if I need help (and I think I will need help).
    Thanks again @dl_doulos and tpylant for your help!
    Sebastian
