  2. Functional Verification
  3. NULL pointer dereference
  • Subscribers 66
  • Views 21198
archive over 18 years ago
I am building an uVC using uRM in SVCB for the First time.
When I wanted to Access the Transaction item from the Driver using "get_next_item" predefined task(defined in urm_driver class library) it is generating an error as,
Error!  NULL pointer dereference
          File: /tools/cadence/ius/tools/urm/src/urm/sv/urm_unit.svh, line = 119, pos = 25
         Scope: top.urm_unit::m_get_message_handler
          Time: 20 NS + 1
Verilog Stack Trace:
0: function top.urm_unit::m_get_message_handler at /tools/cadence/ius/tools/urm/src/urm/sv/urm_unit.svh:119
1: task top.urm_driver::get_next_item at /tools/cadence/ius/tools/urm/src/uvc/sv/urm_driver.sv:546
2: task top.master_bfm@876_2.drive_transfers at   sv/master_bfm.sv:85
3: process in top.master_bfm::run at /sv/master_bfm.sv:58
Infact I am not Using any TLM ports as of now.
I am Puzzled by this error, I will be Thankful for the Suggestions.
Ramesh Pal Yadav
Originally posted in cdnusers.org by ramesh_pal_yadav
    Hi Ramesh,
    I presume you have some statement like:
      sequencer.get_next_item(item);
    in your driver.
    Have you remembered to assign the sequencer instance to the driver sequencer variable in your agent? e.g. you should have something like:
     driver.sequencer = seq_instance;
    where driver and seq_instance are the driver and sequencer instance names in your agent
    If that is OK, have you configured your sequencer correctly?
    Hope that gives you some ideas.
    Dave
    Originally posted in cdnusers.org by dl_doulos
    Hi Dave,
    I dont have a "Sequencer" Instance, Instaed i am accessing the "get_next_item" task from the urm_driver Base Class Library via.. urm_driver_set_sequences_and_item Macro.
       In BFM i have
     driver.get_next_item(seq_item);    where Driver is the instance of my_driver which inherits urm_driver
      In my_driver i have
    urm_driver_set_sequences_and_item(sips_apb_master_transaction)
    This macro initializes the sequence factory for the urm_driver base class method usage and defines the user-defined data item to use when executing urm_simple_sequence.
    This is how I have Implemented uVC Refering to the XBUS golden uVC example.
    I coudnt get what "Configuring the Sequencer" mean? ?
    I haven't started Generation yet and want keep the Basic SIMPLE sequence.I have just made the Environment UP and Proceeding to Work on BFM.
    Ramesh Pal
    Hi Ramesh,
    In the URM XBUS example, the xbus_master_driver is generating sequences - this is what I meant by "Sequencer" (which is the terminology used in the new OVM).
    The BFM (which is called a "driver" in OVM) gets sequence items e.g. by calling driver.get_next_item(seq_item). However, the driver variable must be initialised to point to the object generating the sequences (otherwise you will get a "NULL POINTER" error). In the XBUS example this is done in the build method of xbus_master_agent:
    bfm.driver = this.driver;
    You should have a similar statement in your code.
    My comment about configuring the sequencer is related to the set_*_override functions that can be called to determine what sequences are generated by the factory - see section 2.9 of the svcb user guide.
    Dave
    Hi Dave,
       Thanks a Lot for the Valuable suggestions. The Error is Removed.
    Ramesh Pal
