  2. Functional Verification
  3. Related to URM-svcb
  • Subscribers 66
  • Views 14837
Related to URM-svcb
archive over 18 years ago
Hello friends,
                       I am developing sequence libraries for master & slave using SVCB, i am getting an warning message like this...
WARNING:        SYSTF       XTRARGS
         More arguments passed to $sformatf than specified in format string.
        /home/raghavendrap/UVC/sips_spi_lib/sips_spi/sv/sips_spi_master_seq_lib.sv, 43: $sformatf("Executing a sequence called ",)
                             can anyone suggest what is this warning tells & what are the corrections i have to made inorder to eliminate.
Thanks & Regards
 Raghavendra
Originally posted in cdnusers.org by raghavendrap
    You'll need to look at line 43 in the file sips_spi_master_seq_lib.sv. The compiler is complaining about the extra comma you have in the $sformatf call there. It looks like you are trying to pass a null parameter in addition to the format string. The warning message is saying that there is nothing in the format string (no % format indicator) that tells the tool how you want to display that null parameter.
    Originally posted in cdnusers.org by TAM
