  2. Functional Verification
  3. SV Implementation of dynamic array of memory?
  • Subscribers 66
  • Views 16295
archive over 18 years ago
Hi Friends,
     I want to implement a buffer where I can insert & delete an element flexibly. What I mean to say is something similar to keyed list in specman, I want to implement in SV CB methodology using URM.
   I tried using dynamic memory but I failed creating "new address"(suppose address as my key) for every element I want to add at every other instant of time.
rand int buffer[];
int j = 0;
task ins_element(input [31:0] data);
buffer[j] = new;
buffer[j] = data;
j++;
endtask
Note:  I don't want STACK or FIFO type of implementation here where the array length of memory is static
Here the error is "The function new cannot be used to creat an object to assign to this variable"
Can anyone help me in this regards so as to suggest me how to proceed?
Thanks in advance,
Jalli
Originally posted in cdnusers.org by jaally
    hi Jalli,
    The functionality you want is being implement in below example. I hope it solves your problem.
    Example
    module temp();
    int buffer[];
    int j = 0;
    task ins_element(input [31:0]data);
    buffer = new[j+1](buffer);
    buffer[j] = data;
    j++;
    endtask
    initial
    begin
    ins_element(32);
    ins_element(30);
    ins_element(35);
    ins_element(4);
    #10;
    for (int i = 0 ; i < buffer.size(); i++)
    begin
    $display ( "array values %0d = %0d", i, buffer[i]);
    end
    $finish;
    end
    endmodule
    Result:
    #Loading sv_std.std
    # Loading work.temp(fast)
    # run -all
    # array values 0 = 32
    # array values 1 = 30
    # array values 2 = 35
    # array values 3 = 4
    # ** Note: $finish : temp.sv(25)
    To delete from buffer can use below task.
    task del_element();
    buffer = new[j-1](buffer);
    j--;
    endtask
    I hope it cover your requirement.
    Originally posted in cdnusers.org by divyeshg
    Hi Divyesh,
    Thanks a lot. It did work but I wanna know which book you referred for this so that I can follow the same for SV usage.
    Thanks again,
    Jalli
    Hi Jalli,
    I am referring "SystemVerilog 3.1a Language Reference Manual".
    Hi Divyesh.
    The Accellera 3.1a spec is quite old now, and is not an official standard.
    The best spec to reference is the IEEE1800, which is the official SystemVerilog spec.
    You should be able to view it here:
    http://ieeexplore.ieee.org/servlet/opac?punumber=4410438
    Steve
    Originally posted in cdnusers.org by stephenh
