  2. Functional Verification
  3. End-of-test in SVCB
  • Subscribers 66
  • Views 16277
End-of-test in SVCB
archive over 18 years ago
I am Using URM-IPCM SVCB for the uVC.
For End of the Simulation, I am using the Following code,
task run();
      begin
           #10000  `message(LOW, ("User  activated end of simulation"))
           // Global method - asks to tell all run() phases to end.
           // this will end the simulation.
           global_stop_request();
      end
  endtask : run
This is Ok for me as the Generated  transactions are limited to 30-50 in count Which will take less than 10000 ns simulation time.But if i want more 100+ transactions then i have to call global_stop_request() after ,say some 30000ns.
In this way when i configure the no.of transactions i need to change the delay of global_stop_request() call..rite!!
In eRM, we had an End_of_test mechanism in which objection are raised and dropped automatically calling the End of Simulation.
I want to Know Can we do this type of End_of_test in SVCB also?
Ramesh Pal
Originally posted in cdnusers.org by ramesh_pal_yadav
    I have a similar issue, I think. I don't want to call global_stop_request(), and thought I didn't need to: I figured my sim would stop when there are no more events to process. In fact, it does, and the last line I see is:
    ncsim: *W,RNQUIE: Simulation is complete.
    ncsim> exit
    nchelp ncsim RNQUIE says
    nchelp: 06.20-s003: (c) Copyright 1995-2007 Cadence Design Systems, Inc.
    ncsim/RNQUIE =
    Simulation is complete when there are no future events
    scheduled. This warning indicates that a run command has
    been executed and all current events have been processed.
    Unfortunately, I don't think that my report() function gets called when the sim ends this way ...
    Originally posted in cdnusers.org by vertreko
    I got a solution that works for me, after talking to some Cadence engineers.  Instead of putting global_stop_request() into the run task, where it has no context to understand whether your simulation is really finished, it can be put into the body task of a sequence, as follows:
      virtual task body();
        `message(MEDIUM,("Starting sequence with wr_rd_eeprom_seq"))
        `urm_do_with(wr_seq, { count ==  64; offset ==   0; })
        `urm_do_with(wr_seq, { count ==  64; offset ==  64; })
        `urm_do_with(wr_seq, { count ==  64; offset == 128; })
        `urm_do_with(wr_seq, { count ==  64; offset == 192; })
        `urm_do_with(rd_seq, { count == 128; offset ==   0; })
        `urm_do_with(cr_seq, { count == 128; })
         urm_unit::global_stop_request;
      endtask : body
    Hi Vertreko
    Thanks a Lot , It Worked!!
