  2. Functional Verification
  3. messaging options in UVC
  • Subscribers 66
  • Views 15827
archive over 18 years ago
Hello friends,
                can anyone help me how to print  messages in UVC with different colors, as we do it in eVC.
                                                              Thanks in Advance
Regards
Raghavendra
Originally posted in cdnusers.org by raghavendrap
    This is how you can do it from withing verilog: module test; parameter msg_color_normal = "\033[0m"; // parameter msg_color_red = "\033[1;31m"; // RED parameter msg_color_green = "\033[0;32m"; // GREEN parameter msg_color_yellow = "\033[1;33m"; // YELLOW parameter msg_color_blue = "\033[1;34m"; // BLUE parameter msg_color_purple = "\033[1;35m"; // PURPLE parameter msg_color_ltblue = "\033[1;36m"; // lt blue parameter msg_color_grey = "\033[1;30m"; // GREY parameter msg_color_underline = "\033[1;38m"; // Bold_underline parameter msg_R = "\033[1;31mRED\033[0m "; parameter msg_G = "\033[1;32mGREEN\033[0m "; parameter msg_Y = "\033[1;33mYELLOW\033[0m "; parameter msg_B = "\033[1;34mBLUE\033[0m "; parameter msg_P = "\033[1;35mPURPLE\033[0m "; parameter msg_N = "\033[0mNORMAL\033[0m "; initial begin $display("%0s", msg_color_normal, "This is normal"); $display("%0s", msg_color_red, "This is red"); $display("%0s", msg_color_green, "This is green"); $display("%0s", msg_color_yellow, "This is yellow"); $display("%0s", msg_color_blue, "This is blue"); $display("%0s", msg_color_purple, "This is purple"); $display("%0s", msg_color_ltblue, "This is lt blue"); $display("%0s", msg_color_grey, "This is grey"); $display("%0s", msg_color_underline, "This is Bold Underline"); $display("%0s", msg_color_normal, "This is normal\n"); $display("%0s%0s", msg_N, "This is normal"); $display("%0s%0s", msg_R, "This is red"); $display("%0s%0s", msg_G, "This is green"); $display("%0s%0s", msg_Y, "This is yellow"); $display("%0s%0s", msg_B, "This is blue"); $display("%0s%0s", msg_P, "This is purple"); $display("%0s%0s", msg_N, "This is normal"); end endmodule
    Originally posted in cdnusers.org by tmackett
    sorry, i need to put the answer in HTML format: module test; parameter msg_color_normal = "\033[0m"; // parameter msg_color_red = "\033[1;31m"; // RED parameter msg_color_green = "\033[0;32m"; // GREEN parameter msg_color_yellow = "\033[1;33m"; // YELLOW parameter msg_color_blue = "\033[1;34m"; // BLUE parameter msg_color_purple = "\033[1;35m"; // PURPLE parameter msg_color_ltblue = "\033[1;36m"; // lt blue parameter msg_color_grey = "\033[1;30m"; // GREY parameter msg_color_underline = "\033[1;38m"; // Bold_underline parameter msg_R = "\033[1;31mRED\033[0m "; parameter msg_G = "\033[1;32mGREEN\033[0m "; parameter msg_Y = "\033[1;33mYELLOW\033[0m "; parameter msg_B = "\033[1;34mBLUE\033[0m "; parameter msg_P = "\033[1;35mPURPLE\033[0m "; parameter msg_N = "\033[0mNORMAL\033[0m "; initial begin $display("%0s", msg_color_normal, "This is normal"); $display("%0s", msg_color_red, "This is red"); $display("%0s", msg_color_green, "This is green"); $display("%0s", msg_color_yellow, "This is yellow"); $display("%0s", msg_color_blue, "This is blue"); $display("%0s", msg_color_purple, "This is purple"); $display("%0s", msg_color_ltblue, "This is lt blue"); $display("%0s", msg_color_grey, "This is grey"); $display("%0s", msg_color_underline, "This is Bold Underline"); $display("%0s", msg_color_normal, "This is normal\n"); $display("%0s%0s", msg_N, "This is normal"); $display("%0s%0s", msg_R, "This is red"); $display("%0s%0s", msg_G, "This is green"); $display("%0s%0s", msg_Y, "This is yellow"); $display("%0s%0s", msg_B, "This is blue"); $display("%0s%0s", msg_P, "This is purple"); $display("%0s%0s", msg_N, "This is normal"); end endmodule
    Thanks Mackett,
    But i need that in 'message() format which supports URM-SV Class based methodology for printing my messaging options in colors.
    Regards
    Raghavendra
    Send me an email and I'll send you a complete OVM example. I just tested it using OVM. Similar code should work using the URM library too.
    tmackett@cadence.com
