  2. Functional Verification
  3. print to text file :
  • Subscribers 67
  • Views 16390
archive over 18 years ago
i'm looking for a way to import some verilog signals from my database (.trn file) to textual format or excel spreadshit
(.txt or .xls file).
thanks,
Originally posted in cdnusers.org by zcabeli11
    I suggest you do: shm2vcd and get a VCD file (ASCII text file), then use a mini-parser for signals of interest. If you google, you may even find VCD parser online.
    HTH
    Ajeetha, CVC
    www.noveldv.com
    Originally posted in cdnusers.org by ajeetha
  • dennis2
    dennis2 over 17 years ago
    Where can I find shm2vcd? Is it installed with IUS?
  • tpylant
    tpylant over 17 years ago
    You will need to use the simvisdbutil command.
    To export a VCD database from a SST2 database between 2 and 5 nanoseconds in time :
       % simvisdbutil input_SST2_DB_file_name -vcd -range 2:5ns
    Tim
