  2. Functional Verification
  3. How to use pack and unpack functions in OVM
  • Subscribers 66
  • Views 15119
archive over 18 years ago
Hi friends,
I want to use pack and unpack functions in ovm, I am using  IUS 6.2. ovm_reference is not clear to understand for this topic, can any one say how to use those functions in ovm?
Thanks in advance,
moneesh
Originally posted in cdnusers.org by devangamoneesh
    Check out http://www.ovmworld.org/forums/showthread.php?t=112 for an example.
    Tim
    Originally posted in cdnusers.org by tpylant
    Thanks for reply Mr.Tim
    I saw an example in the link you forwarded, i have coded accordingly, In that example they used bytestream fifo for using pack function, but the error its showing is
    1: Here bytestream used as
    typedef byte bytestream_t [$] ; ----- and error is
    " Using queues, associative arrays, dynamic arrays and strings with the stated construct has not yet been implemented "
    2:and pack declared as
    pack= {<< byte {header,length,payload}}; ---- and error is
    " illegal expression primary "
    Now what i have to do ?
    Thanks & Regards,
    Moneesh
