  2. Functional Verification
  3. need help in $dumpvar function :
  • Subscribers 66
  • Views 16273
archive over 18 years ago
Hello Guys, i'm like to record bus data[31:0] into VCD file. therefore i use the following code: initial begin $dumpvar(0,top.dut.data); end end however , in the VCD file it prints the bus in seperate bits. like this : (verilog.dump file) $var a 1 data[31] $end $var b 1 data[30] $end $var c 1 data[29] $end ... instead of what i expect: $var 32 a data[31:0] $end can anybody tell me how do i refer to data[31:0] as a merged bus and not seperate bits ? thanks ,
Originally posted in cdnusers.org by zcabeli11
    Using the vector notation is the default for the VCD file output. Ordinarily you have to work to get the output in individual bits. You can get the individual bits by declaring the wire as "scalared" or by using the "-expand" option with ncelab. Do either of these apply to your situation?
    Originally posted in cdnusers.org by TAM
    i really want to get the output as vector. however, for some reason i get it seperated ... is there any way to force output as vector ?
