  2. Functional Verification
  3. Functional coverage
  • Subscribers 66
  • Views 18916
Functional coverage
archive over 18 years ago
Hello!
I'm trying to use functional coverage with the IUS6.2 without success. I added the following command when elaborating the design:
-COVFILE configuration_file, and the configuration_file contains coverage -functional -select top -depth all
When elaborating the design the follonwing message is showed in terminal:
ncelab: *N,C57MOD: By default, the old use model for coverage is enabled. IUS6.1 is the last release to support the old use model. Post IUS6.1, only the new use model will be supported.
ncelab: *W,ICFUC: Unknown Command on line 1 of file configuration_file.
Would someone help me? How can I use functional coverage in IUS6.2?
Thank you!
Originally posted in cdnusers.org by mvetromille
    Here are the coverage options for irun (coverage U is for fUnctional):
    % irun -coverage U -covdut top
    Other options would be:
    -covdesign Select coverage design name
    -covdut Select DUT for Coverage
    -coverage Enable coverage instrumentation
    -covfile Specify coverage instrumentation control file
    -covnomodeldump Disable coverage design database (model) dumping
    -covoverwrite Enable overwrite of coverage output files
    -covtest Select coverage test name
    Tim
    Originally posted in cdnusers.org by tpylant
    The coverage command is a ncsim tcl command and should be used as a tcl input file during the simulation, and not a configuration file during ncelab.
    Please file a SR through SourceLink (http://sourcelink.cadence.com) if you need help with generating functional coverage with 6.2.
    Originally posted in cdnusers.org by nlin
