  2. Functional Verification
  3. $Signal_force
  • Subscribers 65
  • Views 16323
$Signal_force
archive over 17 years ago
Hi everyone,
I am trying to use $signal_force but i am running into some problems. I am not sure how to use this command to force a signal not directly to a value but actually to another signal.
to elaborate on this, i give an example.
within my test bench i have a logic signal of size 32 bits called data1 and its value gets updated on each clock cycle. i would like to force a std_logic_vector of 32 bits to data1. but i always get a erro. it seems like i am not allowed to pass a signal as the specified value within signal_force.
$signal_force ("/../../../../input_data", "data1",0,3, ,1)
$signal_force(,,other_options..)
this is where i get the error.
i would like to know if this is legal to do.
Originally posted in cdnusers.org by ROOZ
    I believe the "$signal_force" command is modelsim specific. If you are using modelsim, please consult the modelsim documentation. Cadence Incisive supports a similar command called, "$nc_force()". This is documented in the
    "NC Verilog Simulator Help Manual" in Chapter 19 - Applications.
    Jim McGrath
    Originally posted in cdnusers.org by Jim McGrath
    I did check the questasim documentation but it didn't have an answer to my question. that's the reason for posting the question here. but thanks for your response
