  2. Functional Verification
  3. Quick and easy way to debug your run_scripts in eManage...
  • Subscribers 66
  • Views 15093
Quick and easy way to debug your run_scripts in eManager
archive over 19 years ago
Hi, I often see eManager environments that over use environment variables, overload already overloaded MAKE variables, pass redundant commands into complex shell scripts, launch LSF mulitple times all because end-users are sure about which SHELL or even which type of SHELL is launching the simulations. What we end up doing is launching xterm shells to see what environment variables and Shell types are actually being used and setup by the Cad teams. Then we can run the commands manually from within the xterms. Once we have streamlined and fixed any issues then we can replace the required commandline into the VSIF. Below is a simple XTERM.VSIF which helps us debug and streamline our scripts and environments. /////////////////////////////////////////// session debug_subsystem { top_dir : "./"; output_mode: terminal; pre_session_script: "xterm -title pre_session"; }; group debug_group { scan_script: "$VMANAGER_HOME/bin/vm_scan_default.pl $VMANAGER_HOME/bin/ius_hdl.flt $VMANAGER_HOME/bin/shell.flt "; run_script: "xterm -fg white -bg navy -title run_script"; test debug_test { }; }; /////////////////////////////////////////// Obviously, you can launch xterms from post_session etc. thanks, Adiel.
Originally posted in cdnusers.org by adielkhan
    I am reposting this at it seems the carriage returns got eaten.
    top_dir : "./";
    group debug_group {
    thanks,
    Adiel
