  2. Functional Verification
  3. dynamic probes
  • Subscribers 66
  • Views 16069
dynamic probes
archive over 19 years ago
Hi.
I'm currently studying a solution to dynamically generate an e file with probes and checkers related to the actual configuration of my design.
Do you know if there is a way to access the design hierarchy from either ncsim or specman? I need the same kind of information displayed in the design browser but in a more textual (and possibly parsable) form. Something like:
:my_top_IP
:my_top_IP.compA_0
:my_top_IP.compA_1
:my_top_IP.compB_0.compC_0
Thank you for any suggestion.
Nico
Originally posted in cdnusers.org by nko
    Nico, Specman has a reflect facility (RF) that can dynamically parse the Specman struct/unit hieararchy and generate a meta data file. However, I'm not aware of any such facility in Verilog. Apart from writing your own Verilog parser, one approach might be to decompile the verilog code into a single netlist (using ncdc) and then run a script over it to generate the data that you want. Joseph
    Originally posted in cdnusers.org by jhzhang
    Nico
    ncvlog's tcl interface has a command called "find". You may be able to use it to get information about design hierarchy.
    Nitin
    Originally posted in cdnusers.org by nitin_sharma
    Nico,
       NCSIM has a nice TCL interface that lets you do this easily. A combination of "scope -set" and "scope -describe/-show" plus some TCL coding should do what you want.
    HTH
    Ajeetha, CVC
    www.noveldv.com
    Originally posted in cdnusers.org by ajeetha
