  2. Functional Verification
  3. sequences
  • Replies 17
  • Subscribers 66
  • Views 23500
sequences
archive over 19 years ago
hi dudes, can anybody help me. my question is, while doing eVC with eRM methodology we r using sequences for stimulus generation and If we r not using eRM methodology then how can we generate stimulus? can anybody give me brief about it.
Originally posted in cdnusers.org by vlsi_dude
    first i need to design 2 port arbiter with 100% throughput. i selected algorithm like round robin, priority logic. But all having plus r minus 50% throughput. so i think design fsm with no priority, we get 100% throughput. if you have any idea pls be share it. helpfull for me to design perfectly.
    Ah, OK, I think there's a general sense of miscommunication going on here. Not a problem, but keep in mind that you're asking [i]design[/i] questions on a [i]verification[/i] forum.
    You may benefit more from getting an experienced design consultant in your project to assist you, or search the web for RTL arbiter code examples.
    Good luck!
    Hilmar
    Originally posted in cdnusers.org by Hilmar
    Thanks! c u later
    hi guys,
    anybody can help me on this issue. i trying to link specman with modlesim.
    i'm trying this script.pl. specman invoking modelsim, but specman window is not enable fully.
    And then from modelsim i can't give sn to control the specman because modelsim saying that invalid command.
    system("specman -c \"load ~/env.e; save env.esv; write stubs -qvh");
    system("vlib work");
    system("vcom ./specman_qvh.vhd ~/name.vhd");
    system("specview -p \" restore env.esv; test;\" vsim -keepstdout top_module");
    so give me some comments to link specman with modelsim
    you're probably missing the pli routines.
    try adding
    -pli ${SPECMAN_HOME}/${BRUN_BUILD_OS}/libmti_sn_boot.so
    to your specview call.
    Nils
    Originally posted in cdnusers.org by nls
    whoops, of course ${BRUN_BUILD_OS} must be ${SPECMAN_ARCH}, aka linux, solaris, etc...
    Do you have specman_reference instatiated in VHDL code e.g. in VHDL testbench?
    Originally posted in cdnusers.org by pjigar
