  2. Functional Verification
  3. Coverage customization for multiple eVC instances
  • Subscribers 66
  • Views 16475
archive over 19 years ago
Dear all,
I have the following issue. In my environment I have more instances
of an eRM compliant eVC and each instance has different settings,
then it supports only a subset of the available features. This means
that my coverage will always contain holes (for those items of no
ineterest for a given instance). Does anybody know how to get a
coverage "customized" on the current eVC instance? I mean, is there
a way to tell to Specman that for instance A I want the coverage of
item my_Item limited to values 1, 2 and 3, while for instance B the
values for my_Item can be 2 and 4?
Thanks in advance for your help.
Best regards,
Angelo.
Originally posted in cdnusers.org by angelo.diblasi
    Hi Angelo, just like the rest of Specman, coverage groups (and the items contained within) are extensible. So you can add new coverage items to a coverage group as well as place filtering conditions on existing items. You should consult the Coverage Constructs section (chapter 16) of the e Language Reference manual for details.
    Joseph
    Originally posted in cdnusers.org by jhzhang
    Hi Joseph,
    thanks for you response, I have already gone through that chapter. I also read chapter 8 of the Verification
    Advisor book (honestly it is the manual for Specman 4.3.3, but I suppose it is still valid). Here, in section 8.10.1,
    I found some tips about how to properly collect coverage in structs that have a multiple number of instances
    and it is quite interesting for me the Note 60 and 61, but there I couldn't find any example. Can you help me?
    Angelo
    Which version of Specman are you using?
    Originally posted in cdnusers.org by pjigar
    Hi Angelo,
    Here is a simple filtering example:
    type my_values_t: [A, B, C, D, E, F];
    cover my_values_e is {
    item my_value: my_values_t = ...;
    To filter on a per instance basis, you can:
    cover my_values_e(agent == AG3) is also {
    -- Ignore values D, E, F for this instance
    item my_value using also ignore = (my_value in [D, E, F]);
    Note that this will ignore values D, E and F but [b]only[/b] in the context of cover group my_values_e of agent instance AG3. If my_value is used in other cover groups, you would have to extend them separately.
    Hope this helps,
    -Stelix.
    Originally posted in cdnusers.org by stelix
    Hello Stelix,
    thanks for your reply, this really helps me. I know that some of the
    limitations in coverage modelling have been removed with newer
    Specman versions (starting from 6.0 the per_unit_instance is available).
    Thanks again for your help.
    Kindest regards,
    Angelo.
