  2. Functional Verification
  3. Gen5 list indexing, pop() on empty list
  • Subscribers 66
  • Views 16203
archive over 18 years ago
I encountered some strange error message from IntelliGen when I tried to constrain a field. Even though I know that these few lines cannot completely explain, they might give the right idea.
The user constrains tons of flags that are not checked and can result in invalid combinations. These flags are then condensed into a list of valid flags by a method that takes all flags as argument and returns a list of valid flag values.
error_list : list of bool;
error_list == get_valid_errors(value(user_flag1),value(user_flag2));
The valid length_error flag is then constrained by
keep length_error == value(error_list[some_index]);
based on this valid, confirmed and easy readable flag, the creation should be constrained
keep value(length_error) == TRUE => data_length > 1500; //doesn't really matter what you constrain on the right side
If I tell PGen the generation oder with, keep gen () before () everything works as intended. As IntelliGen ignores those statements, everything should be covered with the value() function for keeping the intended order. But somehow, that doesn't really work.
If I use
keep length_error == value(error_list)[some_index];
I get
List ist empty, cannot access item some_index
Using
results in
Cannot use peseudo-method 'pop()' on an empty list
BTW, that complete environment does NOT contain any pop() method, so it is an internal funtion that uses it. The same code runs fine in Pgen though. If I constrain length_error == TRUE and data_length == 1530, everything runs fine, no contradiction (of course, there shouldn't be any). Both ways of indexing work with PGen. None of them work with IntelliGen. Has anybody encountered that error message before?
greetings
Originally posted in cdnusers.org by SomeDude
    This sounds like you might have some contraint inconsistencies. I recommend running the ICFS linter (inconsistent connected field set), using gen lint -i. This is something wil is recommended to do in general, before you start generating anything. Please also have a look in the user guide which exaplins ICFSs in detail and how to resolve them.
    If you are still experiencing issues, I'd recommend to get the latest version of IntelliGen. We released a hotfix version of SPMN6.2 (SPMN06.20.002-s) at the end of November.
    -hannes
    Originally posted in cdnusers.org by hannes
    Hello Hannes,
    I was already running 002-s and now resolved the error. I had to heavily convert constraints from bidirectional to unidirectional to get it working. (Now Pgen stopped working though)
    I stopped paying attention to icfs in the past because I was not able to write sequences not producing icfs but still working with pgen.
    atm I'm trying to implement ifdefs to keep some constraints made for pgen out of igen and vice versa. Is there any variable I can use for checking which generator is currently being used?
    greetings
    With sufficiently number and complexity of constraints we have found it very difficult to maintain
    backward compatibility to PGen. What we recommend is to use ifdefs, as you mentioned. There
    isn't a define for the generator, since the generator is set using a configuration option/command.
    You could use the SPECMAN_VERSION_nn_nn_OR_LATER define if you want (i.e.
    #ifdef SPECMAN_VERSION_06_20
    // IGen constraints
    #else
    // PGen constraints
    regards,
    -hannes
    Using the Specman Version as decision is not really a solution for me, as my colleagues use the eVC with the same Specman Version I un and they need to use Pgen. We're still waiting for AHB to get ready for Gen5, so till then I have to keep it compatible for both.
    greetings
